Does it matter which version of Linux you use?
- ytiuqibu
- Thank you received: 3
31 Jan 2020 09:45 #156242
by ytiuqibu
Replied by ytiuqibu on topic Does it matter which version of Linux you use?
Thanks Andy,
Both versions now look the same on the Axis screen but I have managed to edit the G-code so that the simulation runs in Axis. Camotics had accepted and run the unaltered G-code.
I will attempt a cut of the altered file tomorrow.
If you are interested I have attached the original G-code It appears to have been fixed by deleting Lines 52 and 323 (322 after deleting line 52.
I am a little puzzled as to why those lines generate a circle and yet the lines that immediately follow them do not. Reading G-code is not my forte and at my age I am somewhat less inclined to delve too far into new coding although I suspect I shall be learning more about G-code, HAL and Python as this project progresses.
Cheers,
Paul
PS - why are .nc files not accepted as attachments?
Cheers,
Paul
- bbsr_5a
- Thank you received: 106
31 Jan 2020 10:20 #156244
by bbsr_5a
Replied by bbsr_5a on topic Does it matter which version of Linux you use?
its a little of topic as G-code talking
you can add nc ending to your INI
[FILTER]
PROGRAM_EXTENSION =
[FILTER]
PROGRAM_EXTENSION =
- ytiuqibu
01 Feb 2020 11:51 #156299
by ytiuqibu
Thanks!
But I was referring to attachments that accompany posts in the forum here where the .nc extension is not acceptable.
- bbsr_5a
01 Feb 2020 12:02 #156303
by bbsr_5a
the interpreter reads the G-code inside and "interprades the Letters"
the ending is not the Factor open TXT file will also work
11 Feb 2020 13:58 #157055
I don't know. I used to have access to the admin interface, and would have added it, but that does not seem to work any more.
Replied by andypugh on topic Does it matter which version of Linux you use?
Time to create page: 0.106 seconds
