2.8 & debian buster
01 Aug 2019 15:14 - 01 Aug 2019 15:15 #141114 by vre
2.8 & debian buster was created by vre
Any solution for this problem with 2.8pre1 & debian buster ?
( depedencies python-gtksourceview2 & python-vte are not available on buster )
Also when final 2.8 will be released ?
# cat /etc/debian_version
10.0
# dpkg -i linuxcnc-uspace_2.8.0~pre1_arm64.deb
Selecting previously unselected package linuxcnc-uspace.
(Reading database ... 179999 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.8.0~pre1_arm64.deb ...
Unpacking linuxcnc-uspace (1:2.8.0~pre1) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
 linuxcnc-uspace depends on python-gtksourceview2; however:
  Package python-gtksourceview2 is not installed.
 linuxcnc-uspace depends on python-vte; however:
  Package python-vte is not installed.
dpkg: error processing package linuxcnc-uspace (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for systemd (241-5) ...
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for shared-mime-info (1.10-1) ...
Errors were encountered while processing:
 linuxcnc-uspace
# apt-get install python-gtksourceview2 python-vte
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package python-gtksourceview2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package python-vte is not available, but is referred to by another package.
E: Package 'python-gtksourceview2' has no installation candidate
E: Package 'python-vte' has no installation candidate
Last edit: 01 Aug 2019 15:15 by vre.
  • Moderator
  • Moderator
01 Aug 2019 15:23 #141117 by tommylight
01 Aug 2019 17:37 #141130 by vre
Replied by vre on topic 2.8 & debian buster
No
I want armbian buster it is debian buster based.
The hardware is rockpro64 so mint does not work
  • Moderator
  • Moderator
01 Aug 2019 18:37 #141132 by tommylight
Replied by tommylight on topic 2.8 & debian buster
Ok.
01 Aug 2019 22:01 - 01 Aug 2019 22:05 #141153 by Bari
Replied by Bari on topic 2.8 & debian buster
This thread should have been better labeled as 2.8 & Debian Buster on ARM/Rpi
Pretty sure we just removed those dependencies at it worked for Buster. Sid is similar.
Last edit: 01 Aug 2019 22:05 by Bari.
08 Aug 2019 12:20 #141671 by andypugh
Replied by andypugh on topic 2.8 & debian buster
I have compiled LinuxCNC on RPi / Buster in the last few weeks, so it can be done.
The dependency on python-vte was removed a month ago (nothing used it). I don't rememeber what I did about gtksourceview.
The following user(s) said Thank You: vre
20 Aug 2019 01:58 #142535 by vre
In which branch these deps removed in 2.8 or master?
20 Aug 2019 02:18 #142537 by cmorley
Replied by cmorley on topic 2.8 & debian buster
Actually Gscreen does use it - though I believe i made it not crash if it's missing.
Chris M
20 Aug 2019 09:16 - 20 Aug 2019 19:42 #142564 by vre
I cloned the git repo today and the deps exist yet
Is the problem to config script for debian packages ?
Anyway i have force installed ignoring the dependencies
but gmocappy does not work because it depends to python-gtksourceview2
(I have cloned this repo github.com/LinuxCNC/linuxcnc)
# dpkg -i linuxcnc-uspace_2.9.0~pre0_arm64.deb
(Reading database ... 180124 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.0~pre0_arm64.deb ...
Unpacking linuxcnc-uspace (1:2.9.0~pre0) ...
 linuxcnc-uspace
Last edit: 20 Aug 2019 19:42 by vre.
29 Feb 2020 21:10 - 29 Feb 2020 21:13 #158841 by Lebensgefahr
Replied by Lebensgefahr on topic 2.8 & debian buster
You can take python-gtksourceview2 from Ubuntu repository (i use it from 18.04) and install it with dpkg -i python-gtksourceview2. After it will write an error of missed dependencies you just need to execute apt-get install -f to fix broken dependencies. After that it will be installed without any warnings and errors.
Btw there is a buildbot buildbot.linuxcnc.org/ where you can find repository to add it to your apt sources list /etc/apt/sources.list.d
Last edit: 29 Feb 2020 21:13 by Lebensgefahr.
