LinuxCNC often freezes hard on (Not released) RTAI 4.14.132
- pl7i92
 - Thank you received: 358
						12 Aug 2019 10:17				#141959
		by pl7i92
				LinuxCNC often freezes hard on RTAI 4.14.132 was created by pl7i92
				hi
welcome
is there a USB connected or a parport not well icolated
this can be a reason
please try unplug the mouse and replug it if it is responding
					welcome
- neller
						13 Aug 2019 09:52				#142019
		by neller
				Replied by neller on topic LinuxCNC often freezes hard on RTAI 4.14.132
				Thank you for your advice, but keyboard and lpt isn't a reason now. I tryed to replug it, but freezes still happens. I noticed freezes appears only when I launch LinuxCNC, Latency-test or close them. I think the reason related with RTAI kernel. Can you please say me how to investigate the issue? Thank you.
 - Thank you received: 4559
						13 Aug 2019 11:08				#142024
				Replied by andypugh on topic LinuxCNC often freezes hard on RTAI 4.14.132
				Where did you get 4.14.132 from?
Does the latency test also freeze?
How about the RTAI testsuite?
- neller
						13 Aug 2019 13:36				#142025
		by neller
				1. Using guides on github.com/andypugh/RTAI/releases and wiki.linuxcnc.org/cgi-bin/wiki.pl?Building_RTAI_5.2_Packages
2. Yes, when I start latency-test the PC often freezes, only reboot can solve the problem.
3.How to use testsuite?
Thank you!
Thank you!
- pl7i92
						13 Aug 2019 15:12				#142031
		by pl7i92
				Replied by pl7i92 on topic LinuxCNC often freezes hard on RTAI 4.14.132
				just to be shure
latencytest is startet without Linuxcnc running
and also te oposit
no latency test while linuxcnc is running
if you got a Stepper mashine to be configured you migt not need at all latency test most reson pc got below 100k
and 100k is the standard timing for steppers
if you use mesa ethernet also no need of latency check
But it is alway good to know here the hint of the pc is
and also te oposit
 - Thank you received: 7115
						13 Aug 2019 15:22				#142033
				Replied by tommylight on topic LinuxCNC often freezes hard on RTAI 4.14.132
				Just a stab in the dark, but, check :
Old / failing power supply.
Overheating processor / cooler not seated properly or no thermal compound on it.
Failing memory / memory controller on the board.
Less likely, graphic card Ram failing.
						13 Aug 2019 17:36				#142054
				This might be the RTAI build. The reason I made those builds on GitHub was that the other builds I tried all crashed. After a lot of config changes we finally got a setup that worked on my test hardware, and some others and that is what was published (specifically so potential problems could be found).
The RTAI testsuite is (I think) in /usr/realtime/kern/testsuite (some path like that, I am not on an RTAI machine at the moment, I am in a hotel room with a Mac). You need to run the "display" executable with sudo privileges.
- Bari
 - Thank you received: 232
						15 Aug 2019 22:10		 -  15 Aug 2019 23:53		#142290
		by Bari
				Replied by Bari on topic LinuxCNC often freezes hard on RTAI 4.14.132
				Don't use the no-calibration branch and those debs are broken. NTU was not done when Andy built those.
The working branch is here, only use master:
github.com/NTULINUX/RTAI
After the no-calibration branch is fixed then Andy may go ahead and rebuild based on his fork. If you want stable.
		Last edit: 15 Aug 2019 23:53  by Bari.
- Bari
						08 Oct 2019 01:31				#147403
		by Bari
				No-calibration branch is fixed. Please resume testing.
- neller
						13 Jul 2020 20:43				#174536
		by neller
				I also have this issue on 4.14.148 (no-calibration branch). In kern.log i found this line "^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@" (while freeze happed). Where can I find more messages?
		Time to create page: 0.551 seconds
