Raspberry Pi 4 RT Preempt Kernel
- fixer
- Thank you received: 27
18 Aug 2019 15:28 #142442
by fixer
Replied by fixer on topic Raspberry Pi 4 RT Preempt Kernel
apt install python-yapps
The following user(s) said Thank You: BigJohnT
- Hakan
- Thank you received: 454
18 Aug 2019 18:39 #142450
by Hakan
Replied by Hakan on topic Raspberry Pi 4 RT Preempt Kernel
wicki published (in another thread) a list of packages to install, that can give a hint.
There are many packages to install
erste.de/raspi4-RT-kernel-howto.html#compile_linCNC_on_Raspi4
Is there any way this can be incorporated into the standard installation procedure?
- BigJohnT
- Thank you received: 994
18 Aug 2019 23:42 #142463
by BigJohnT
What "standard installation procedure" are you speaking about?
JT
Replied by BigJohnT on topic Raspberry Pi 4 RT Preempt Kernel
JT
- BigJohnT
18 Aug 2019 23:45 - 18 Aug 2019 23:47 #142464
by BigJohnT
Last edit: 18 Aug 2019 23:47 by BigJohnT.
- Hakan
19 Aug 2019 07:52 #142477
by Hakan
I was thinking of the standard linuxcnc installation.
There is nothing special in that for the RPi4, only the dependencies need to be resolved.
When they are resolved, it is just to compile linuxcnc following the usual linuxcnc instructions.
The raspbian is based on buster so there can be many things gotten for free from the Intel buster.
I guess. I think of the "dpkg-checkbuilddeps" command but don't know how that works.
And I gave away my RPi4 yesterday, so I can't check.
JT
- BigJohnT
19 Aug 2019 11:06 #142486
by BigJohnT
- Thank you received: 7478
19 Aug 2019 13:15 #142491
Replied by tommylight on topic Raspberry Pi 4 RT Preempt Kernel
Looks pretty good for a pi.
Thank you.
Thank you.
- BigJohnT
21 Aug 2019 23:24 #142749
by BigJohnT
My build instructions are over on my web site gnipsel.com/linuxcnc/uspace/
Just doing it again to make sure I don't have any mistokes.
JT
JT
- qwerasdferty
20 Nov 2019 03:51 - 07 Apr 2020 09:38 #150716
by qwerasdferty
Replied by qwerasdferty on topic Raspberry Pi 4 RT Preempt Kernel
John,
I walked through the whole Raspberry install and build process today and it worked great except for one minor blip.
"Now build and install LinuxCNC
debuild -uc -us"
should be
sudo debuild -uc -us"
I think.....without sudo it would error out and halt.
Thanks for all the effort you put into this John!!
debuild -uc -us"
should be
Last edit: 07 Apr 2020 09:38 by qwerasdferty.
- Thank you received: 4654
24 Nov 2019 22:42 #151154
Replied by andypugh on topic Raspberry Pi 4 RT Preempt Kernel
You can download pre-built preempt-rt kernels here:
packages.debian.org/search?keywords=linux-image-rt
Or you can download a Raspian SD card image, with preempt-rt kernel from here:
unofficialpi.org/Distros/RealtimePi/nightly/
Time to create page: 0.626 seconds
