I followed the tutorial except I downloaded the raspbian desktop image prior to finding the tutorial so I am not on OpenBox.
When I try to run linuxcnc I get the following.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/pi/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
INIFILE=/home/pi/linuxcnc/configs/sim.axis/axis.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Realtime system did not load
Debug file information:
/usr/bin/linuxcnc: line 747: /etc/init.d/realtime: No such file or directory
1589
Stopping realtime threads
Unloading hal components
/usr/bin/linuxcnc: line 643: /etc/init.d/realtime: No such file or directory
uname -a produces
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Sun Apr 12 08:51:30 CDT 2020 armv7l GNU/Linux
Any what went wrong. I had some issues with installing packages due to internet connectivity but after rerunning packages that did not install correctly at first I thought it all installed and compiled correctly.
Thanks,
Jim
