Raspberry Pi 4 Tutorial - fatal error
19 Feb 2021 14:57 #199442 by tommylight
Replied by tommylight on topic Raspberry Pi 4 Tutorial - fatal error
Either the system freezes immediately after the restart following the notification: resize file system.
That takes a long time on SD cards, so wait a bit more.
This is preceded by a message: Error: cpu 0 not supported
This is for KVM, it can be safely ignored as it has no impact on functionality.
19 Feb 2021 15:29 #199448 by andypugh
Replied by andypugh on topic Raspberry Pi 4 Tutorial - fatal error
I have the same problem with both version
Or the system freezes as soon as the desktop is displayed.
That's _not_ the same problem, as far as I can tell. This is a different problem to the ones that I hoped to have solved with the new SD card.
1) Ignore the "KVM CPU0 Not supported". You do not need KVM to run LinuxCNC. In fact it would be foolish to try
2) Give it some time when resizing the file system. If 10 minutes doesn't see signs of life then try rebooting as-is.
19 Feb 2021 17:21 #199460 by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4 Tutorial - fatal error
Maybe wrong place but:
Not with lcnc I remarked that in upgrading pi4 with latest raspbian they loaded new bios/firmware. Maybe it could be a solution to run till newest Raspbian to get compatibility of the bios....
Mike
20 Feb 2021 08:33 #199502 by jaro_p
Replied by jaro_p on topic Raspberry Pi 4 Tutorial - fatal error
I tried it with SanDisk 32GB Extreme µSD cards, I replaced 3.
But I'll try another one.
Time to create page: 0.532 seconds
