Raspberry Pi 4 Tutorial - fatal error
- LearningLinuxCNC
- Thank you received: 39
13 Apr 2020 14:16 #163875
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Raspberry Pi 4 Tutorial
I followed the tutorial except I downloaded the raspbian desktop image prior to finding the tutorial so I am not on OpenBox.
When I try to run linuxcnc I get the following.
uname -a produces
Any what went wrong. I had some issues with installing packages due to internet connectivity but after rerunning packages that did not install correctly at first I thought it all installed and compiled correctly.
Thanks,
Jim
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/pi/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
INIFILE=/home/pi/linuxcnc/configs/sim.axis/axis.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Realtime system did not load
Debug file information:
/usr/bin/linuxcnc: line 747: /etc/init.d/realtime: No such file or directory
1589
Stopping realtime threads
Unloading hal components
/usr/bin/linuxcnc: line 643: /etc/init.d/realtime: No such file or directory
-----------------------------------------------------------------------uname -a produces
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Sun Apr 12 08:51:30 CDT 2020 armv7l GNU/LinuxAny what went wrong. I had some issues with installing packages due to internet connectivity but after rerunning packages that did not install correctly at first I thought it all installed and compiled correctly.
Thanks,
Jim
- LearningLinuxCNC
14 Apr 2020 02:05 #163914
by LearningLinuxCNC
So I went back and redid the install from scratch and now everything is working. Don't know what was broken but it is now fixed.
Thanks for the tutorial BigJohnT!
- BigJohnT
- Thank you received: 994
14 Apr 2020 23:23 #163989
by BigJohnT
Replied by BigJohnT on topic Raspberry Pi 4 Tutorial
Jim,
I gotta ask what is it that you have that has 662HP with 5.8L? My best is my 385HP 5.7L Corvette.
JT
JT
- Thank you received: 7485
14 Apr 2020 23:32 #163992
Many can do that without turbo chargers or superchargers. But that 5.8 is suspicious !
Replied by tommylight on topic Raspberry Pi 4 Tutorial
An import ?????Jim,
JT
- sprintertrd
15 Apr 2020 00:43 #163997
by sprintertrd
Replied by sprintertrd on topic Raspberry Pi 4 Tutorial
Is'nt 5.8L = 351cuin = Ford
- LearningLinuxCNC
15 Apr 2020 13:04 #164058
by LearningLinuxCNC
Not an import!
2014 GT500. Supercharged 5.8L Dual overhead cam. 662 HP 631FT-LB Torque. 400FT-LB from about 2K to 6500.
That thing was a beast. I don't have it anymore. I had it for 3 years. Drove it a total of 5000 miles and over 1000 miles were put on in two trips. It was black on black on black. While it looked beautiful when it was clean it was never clean. I literally spent more time washing the car than I did driving it.
The main problem with driving it is that it had no traction in 1st gear. you could roll into the throttle and it would start spinning the tires at 50mph.
Most of the time I would demonstrate the power of the car by doing a 60mph roll pull in second gear. You shift from first to second at 62mph. Here is a video of me and my dad in the car doing a 60 to 90 mph pull. Shift to 3rd at 90.
The replacement is a 2000 Ford SVT Lightning pickup truck. It is no GT500 but it will do in a pinch ; )
A little off topic, but you brought it up!
The following user(s) said Thank You: BigJohnT, tommylight
- BigJohnT
15 Apr 2020 16:35 - 15 Apr 2020 16:38 #164065
by BigJohnT
That's pretty impressive, I just can't imagine a supercharger on my corvette! For me 385 HP is plenty in a car that weighs 3,246 pounds and will pull 0.9G's in a corner. Thanks for the video.
JT
JT
Last edit: 15 Apr 2020 16:38 by BigJohnT.
- LearningLinuxCNC
15 Apr 2020 22:16 #164090
by LearningLinuxCNC
Trying to run halcompile on this install on the rpi4 and the result returns
What do I need to do with this install to make halcompile work? I tried to run
while in the emc drectory where the source was downloaded but that does not work either. It returns
Any ideas?
bash: halcompile: command not foundWhat do I need to do with this install to make halcompile work? I tried to run
sudo make setuidwhile in the emc drectory where the source was downloaded but that does not work either. It returns
make: *** No rule to make target 'setuid'. Stop.Any ideas?
- LearningLinuxCNC
15 Apr 2020 22:19 #164091
by LearningLinuxCNC
On another side note: I had my first ESD incident with the rpi4 yesterday. I woke up early came into the office sat down to start working on the issue I posted above and touched the usb ports on the rpi4 and snap!
The pi would not power up. I ordered replacements of the board and the power adapter. I plugged in the new board to the old power adapter and no joy. I plugged the new board into a new power adapter and it works. I have not tried a new power adapter with the old board yet . . . I am afraid it will toast a new power adapter with a short on the board.
What do you think?????
- LearningLinuxCNC
16 Apr 2020 21:54 #164204
by LearningLinuxCNC
No ideas on this one. I need halcompile to work for the project that I am working on.
sudo make setuid
Any ideas?
Time to create page: 0.143 seconds
