Upgrade to 2.7.14 from 2.7.0
- garthnoakes
- Thank you received: 9
01 Nov 2019 03:40 #149331
by garthnoakes
Upgrade to 2.7.14 from 2.7.0 was created by garthnoakes
Has anyone done this? does it work? what does it require in terms of config file changes?
- pl7i92
- Thank you received: 358
01 Nov 2019 07:48 #149335
by pl7i92
Replied by pl7i92 on topic Upgrade to 2.7.14 from 2.7.0
Hi
below 2.8 all files are the same from 2.5 upwards
so no risk
see the advice on how to edit depencies to update
Good advice is to use Synaptic to see first hat is gone be installed and not just install
make a backup of your config folder
and the ngc files inside nx_folder
so no risk
The following user(s) said Thank You: garthnoakes
Time to create page: 0.080 seconds
