How do I add linuxcnc repository on debian
- Bigben88
07 Dec 2019 11:57 #152237
by Bigben88
How do I add linuxcnc repository on debian was created by Bigben88
Hey folks,
I recently decided to get linuxcnc for my cnc mill and tried to install Debian and Linuxcnc on an old Laptop I still got laying arount.
Installing debian was´nt a problem but I can´t get the repository via shell command.
So wehen I try:
I get
in return.
The RT Kernel is running. But I have´nt been using Linux for quite some time.
Would be great if someone could help me out there.
PS: Hope this is the right place for that topic, if not please relocate...
So wehen I try:
sudo add-apt-repository "deb http://linuxcnc.org/ wheezy base 2.7-uspace"I get
command not foundin return.
- 0x2102
- Thank you received: 88
07 Dec 2019 14:27 #152250
by 0x2102
Replied by 0x2102 on topic How do I add linuxcnc repository on debian
- Bigben88
08 Dec 2019 12:27 #152326
by Bigben88
Replied by Bigben88 on topic How do I add linuxcnc repository on debian
First of all thanks for the quick response. Now I did as described in the linked page but when I got to the install step I got another error message:
So still no luck there.
Unable to correct problems, you have held broken packagesSo still no luck there.
- Bigben88
17 Dec 2019 16:29 #152797
by Bigben88
Iḿ still trying to work out my install problems.
I got Buster running because for some reason the linuxcnc image did'nt install as it should (during install process the software packages could'nt be installed, so no KDE or GNOME)
I followed the instructions as shown here: Debian10 LinuxCNC install guide
Everything worked up to this point:When I tried to modify the files linux told me I'm not authorized (even as root, which I tried after the first attempt failed).
I also could'nt find LinuxCNC in the applications, so it does'nt seem to be installed, even if it should be, right?
Can anybody tell me what I'm missing here?
PS: Sorry for the bad english
modify the following files
debian/control.bottom.in
remove python-gtksourceview2, on line 14
remove python-vte
debian/control
remove python-gtksourceview2, on line 68
remove python-vte
- 0x2102
17 Dec 2019 17:33 #152801
by 0x2102
The guide is for installing LinuxCNC from source and compile it. Not sure if this is the best approach for you.
Maybe try downloading Debian 9 with Linuxcnc ISO - burn it to USB/DVD and install it.
www.linuxcnc.org/testing-stretch-rtpreempt/
Image for 32Bit System: (i386)
linuxcnc-stretch-uspace-i386-r13.iso
- Bigben88
17 Dec 2019 18:19 #152806
by Bigben88
Thanks but installing the LinuxCNC ISO was one of the instances where I could´nt install GNOME or KDE, so that option is out. Same with Debian 9 (no GNOME or KDE; even with bash commands). I also tried Ubuntu.
My last attempt failed when I tried to install LinuxCNC via KDebi: "missing dependency, libboost-python1.62.0".
So far that´s still my best bet, but I can´t find that "libboost-python1.62.0" anywhere xept for dead/404 websites
- Thank you received: 7490
17 Dec 2019 18:26 #152808
Replied by tommylight on topic How do I add linuxcnc repository on debian
I did install Mate several times on Stretch, worked properly.
- 0x2102
17 Dec 2019 18:41 - 17 Dec 2019 18:48 #152809
by 0x2102
I have to ask, why would you want to install Gnome or KDE on an old Laptop? Maybe try installing Debian 9 and run latency tests first, before you spend more time on this.
Last edit: 17 Dec 2019 18:48 by 0x2102.
- Bigben88
18 Dec 2019 15:42 #152849
by Bigben88
@tommylight: For me it did´nt.
@0x2102: "Old Laptop" as in 10 years old, I do´nt see a problem there. My main goal is to get LCNC up and running to see how working with my CNC-Mill via LCNC is gonna be. ATM I dont even have a cloosed loop system installed; just good old stepper motors. For that I dont need latency tests but a working interface/machine controller.
So does anyone here know where to find a downloadable "libboost-python1.62.0" file? Maybe a link? I´d really appreciate it.
18 Dec 2019 16:19 #152851
Did you enable the source code repositories in the software sources ?
Time to create page: 0.127 seconds
