Linuxcnc 2.7.14 not booting
- PeteJM
09 Dec 2019 21:48 #152394
by PeteJM
Linuxcnc 2.7.14 not booting was created by PeteJM
Hi All,
I have tried installing Linuxcnc 2.7.14 onto my computer but i cannot seem to get it to boot on startup, after writing it to a bootable usb, i have followed the 'getting linuxcnc page'. I've verified it and used the dd command. When I restart with the usb it doesn't boot, i have checked boot options on startup but the usb is not listed but it worked fine when i installed ubuntu earlier. I have also wrote another usb on my windows 10 computer (how i did the ubuntu install) but still no luck.
Does anyone have a solution to this?
Cheers.
Cheers.
- Thank you received: 7490
09 Dec 2019 23:13 #152407
Replied by tommylight on topic Linuxcnc 2.7.14 not booting
Try win32imager or rufus.
DD worked for me always.
- PeteJM
10 Dec 2019 07:54 #152420
by PeteJM
Replied by PeteJM on topic Linuxcnc 2.7.14 not booting
I've tried it using rufus but it still doesn't work
10 Dec 2019 11:39 #152429
Did you try to boot it on another PC?
- PeteJM
10 Dec 2019 13:34 #152434
by PeteJM
Yes, have tried it on 2 PCs not showing on boot options on either. I have wrote a different program the same way to usb and it boots up no problem.
- Online
- Thank you received: 1480
10 Dec 2019 16:11 #152441
Replied by Todd Zuercher on topic Linuxcnc 2.7.14 not booting
Have you checked the MD5 of the image you downloaded? Maybe you just have a bad copy and need to try to download it again.
- PeteJM
10 Dec 2019 18:12 #152448
by PeteJM
Yes, have downloaded 2 copies on separate computers and done MD5sum on both and they both are ok. Should i try and download using zsync?
- Thank you received: 5334
10 Dec 2019 18:32 #152449
Replied by PCW on topic Linuxcnc 2.7.14 not booting
What PC hardware and what LinixCNC image?
The Wheezy image may not boot on some newer hardware
- PeteJM
10 Dec 2019 18:49 #152450
by PeteJM
Its a HP Pavilion G6 laptop, i downloaded Linuxcnc-2.7.14-wheezy.iso
10 Dec 2019 18:54 #152451
Not sure what vintage that is (there seem to be new and old G6 models)
but you might try the stretch ISO
