Adding Persistence to LiveCD for LinuxCNC Simulation
- ytiuqibu
- Thank you received: 3
29 Dec 2019 12:27 #153430
by ytiuqibu
Adding Persistence to LiveCD for LinuxCNC Simulation was created by ytiuqibu
Is it possible to add persistence to the hybrid images for LinuxCNC installation?
- Thank you received: 7490
30 Dec 2019 00:54 #153535
Replied by tommylight on topic Adding Persistence to LiveCD for LinuxCNC Simulation
Have not used it for a while but i think it is possible but to much trouble. It does not use CASPER as the Ubuntu and it's derivates like Mint, for them it is very easy to add persistence, you can even partition a part of the drive ( HDD, SSD, USB ) and name it casperrw and add a line to grub, it will use that whole partition for persistence.
- ytiuqibu
30 Dec 2019 11:52 #153547
by ytiuqibu
Replied by ytiuqibu on topic Adding Persistence to LiveCD for LinuxCNC Simulation
Thanks very much - I will try it.
- ytiuqibu
04 Jan 2020 23:24 #154046
by ytiuqibu
I have abandoned the LiveCD approach in favour of a full install, first using AgentWD40's method but (given I have several computers to install and none of them actually drives machinery) I will next attempt your 'quick and easy installation' method.
Thanks once again for your help!
05 Jan 2020 02:01 #154066
You are welcomed, always.
Time to create page: 0.161 seconds
