RTAI for Stretch/Buster and rabbit holes
- JohnnyCNC
- Thank you received: 115
02 Jan 2020 01:18 #153757
by JohnnyCNC
RTAI for Stretch/Buster and rabbit holes was created by JohnnyCNC
I spend the day trying to get a version of either Debian Stretch or Buster with RTAI and 2.8 working. I have a preempt version of Stretch with 2.8. I have looked at many different posts and followed several different sets of instructions all of which lead to one impasse or another. That lead me to the question of what do I need to do to get from Stretch preempt to RTAI? Can I get pre-built kernel or do I have to build it myself? About 8 months ago I did get through the process of building a preempt kernel but this one has just beat me.
- phillc54
- Thank you received: 2100
02 Jan 2020 03:22 #153765
by phillc54
Replied by phillc54 on topic RTAI for Stretch/Buster and rabbit holes
I have installed the packages from github.com/andypugh/RTAI/releases and they work fine.
The only issue for me is that it restricts boards with Intel graphics to 1024x768 resolution. The developers are working to rectify this.
- JohnnyCNC
02 Jan 2020 03:30 #153766
by JohnnyCNC
Replied by JohnnyCNC on topic RTAI for Stretch/Buster and rabbit holes
I'll try that one again tomorrow.
- JohnnyCNC
03 Jan 2020 03:57 #153858
by JohnnyCNC
Tried again and made it to "REBOOT". Then it would no longer boot. It gives an error: "kernel not compile with retpoline; no mitigation available"
I does mention BusyBox v1.22.1 on the screen and I end up at what looks like a prompt (initramfs). At this point it does not accept input from the keyboard.
$ sudo make
$ sudo make install
$ sudo make modules_install
On debian this will automatically update grub and set the system to boot from the new kernel.
REBOOT (and check with uname -r that the new kernel is running: 4.14.132-rtai-amd64
If it boots to the busybox boot to the old kernel then run these commands JT
cd /usr/src/linux
sudo make install
$ sudo make
$ sudo make install
cd /usr/src/linux
sudo make install
07 Jan 2020 23:01 #154278
Replied by andypugh on topic RTAI for Stretch/Buster and rabbit holes
- JohnnyCNC
08 Jan 2020 02:33 #154285
by JohnnyCNC
I did find them and installed the image and headers but it still shows as PREEMPT.
When booting in complains that the kernel is not compiled with "Retpoline" no mitigation available.
I guess that is OK but possibly risky.
$ cat /sys/devices/system/cpu/vulnerabilities/spectre_v2
Vulnerable, IBPB: disabled, STIBP: disabled
Am I just not understanding how to tell if this is RTAI or PREEMPT?
Linux X3CNC 4.14.148-rtai-amd64 #2 SMP PREEMPT Sat Nov 9 16:29:10 GMT 2019 x86_64 GNU/Linux
I also tried these and it boots with the same warning..
linux-headers-4.14.132-rtai-amd64_4.14.132-rtai-amd64-1_amd64.deb
linux-image-4.14.132-rtai-amd64_4.14.132-rtai-amd64-1_amd64.deb
08 Jan 2020 10:40 - 08 Jan 2020 10:40 #154296
PREEMPT is a common feature of all Linux kernels. PREEMPT-RT is the realtime variant.
en.wikipedia.org/wiki/Kernel_preemption
Yes. I haven't looked in to whether RTAI is compatible with spectre mitigation. I have been ignoring that warning.
Describes the vulnerability. You might want to consider whether this is a problem to you on your CNC controller.
When booting in complains that the kernel is not compiled with "Retpoline" no mitigation available.n
Last edit: 08 Jan 2020 10:40 by andypugh.
Time to create page: 0.243 seconds
