RealTek wifi drivers
- claytoncramer
22 Jan 2020 01:07 #155382
by claytoncramer
RealTek wifi drivers was created by claytoncramer
I recently had to say goodbye to a 2003 laptop that I was using to run linuxcnc. Trying to get antiques repaired is hopeless. The "new" computer has a RealTek USB WiFi gadget, but it is invisible during install, so I have no Internet connection. I have received a driver set that purports to support Linux. Chipset is RTL8188. There is an easy install.sh, but it seems to do nothing but compile source. Help!
- BeagleBrainz
- Visitor
22 Jan 2020 03:57 #155394
by BeagleBrainz
Replied by BeagleBrainz on topic RealTek wifi drivers
The issue with the RTL device when installing debian is that the required firmware does not conform to Debian strict OSS policy.
The "new" computer, has it not got an Ethernet port ?
Maybe if you throw up some specs of the new machine and the Linuxcnc version you wish to install.
Is it possible to install the hdd out of the Laptop into the new machine ?
- Thank you received: 7490
22 Jan 2020 17:07 #155434
Replied by tommylight on topic RealTek wifi drivers
This will save you a lot of headaches :
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
26 Jan 2020 20:58 #155850
During the install process there might have been a question asked about installing closed-source drivers.
If you answer yes at that point there is a chance that the dongle will work
(I have the same problem on a multi-boot machine with three different Linuxes, some can run the dongle, some can't depending on what I pressed when that question came up)
Replied by andypugh on topic RealTek wifi drivers
The "new" computer has a RealTek USB WiFi gadget, but it is invisible during install,!
- claytoncramer
26 Jan 2020 23:52 #155869
by claytoncramer
Replied by claytoncramer on topic RealTek wifi drivers
Was never asked the question. I bought a TP-LINK USB adapter, and TP-LINK customer service seems to have rolled a device driver for my obsolete version of debian. Everything is working. TP-LINK advertised Linux support and they went above and beyond my expectations.
Time to create page: 0.099 seconds
