MXLinux - would this be a good choice?
- fiskrond
05 Feb 2020 09:39 #156568
by fiskrond
MXLinux - would this be a good choice? was created by fiskrond
Mornin' all. First post..
My background is general accounts/admin & hobby PC builder.... I've recently started using MXLinux (as in home use.. just office & internet stuff).. so I'm just getting on the learning curve.
A mate needs me to build a PC to run 'machines' and has told me he needs LinuxCNC to run them. I've got several old PCs available.. mostly 32-bit Pentium4 era which we hope to utilise, and we can go from scratch with these.
Being based on Debian, would MXLinux be suitable for installing LinuxCNC?
Thanks in advance!
Thanks in advance!
- prospec68
05 Feb 2020 10:00 #156571
by prospec68
Replied by prospec68 on topic MXLinux - would this be a good choice?
At least on MXLinux 18 I was able to install 2.8 and the gmoccapy (sim...) worked fine.
- BeagleBrainz
- Visitor
05 Feb 2020 10:10 #156575
by BeagleBrainz
Replied by BeagleBrainz on topic MXLinux - would this be a good choice?
One of the most reliable ways to get up and running would be use a pre-built iso.
For a pentium 4 era machine I'd look at this
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
More info on this page:
www.linuxcnc.org/downloads/
Yeah yeah I know Wheezy has been archived but it would probably the best bet on such "old" machines. Now I'm assuming you are going to use a parallel port and a breakout board. USB isn't supported, no realtime support for USB.
Now there is no reason why you couldn't MXLinux, haven't used it myself, but a prebuilt iso would give your more time actually building & configuring your hardware, rather than chasing dependencies. Unless of course you are familiar with building "The Debian Way".
I've built Linuxcnc on Slackware & Salix but it wasn't for the faint of heart.
- Thank you received: 7490
05 Feb 2020 10:22 #156578
Replied by tommylight on topic MXLinux - would this be a good choice?
You can try MX and install the rtai kernel and Linuxcnc from linuxcnc.org/temp.
See the quick install of Mint on the forum, if it works it will take about 20 to 30 minutes to have it up and running.
- fiskrond
05 Feb 2020 10:26 - 05 Feb 2020 10:28 #156579
by fiskrond
Replied by fiskrond on topic MXLinux - would this be a good choice?
Yep.. parallel ports on the PCs for time being (limited budget). Connection at the machine end is being taken care of by someone who knows the kit.
I live a good way from the site... so ideally we need to be using same base Linux system in order for interim comms otherwise it'll get hellishly confusing real quick!
I'm easy with regards to what we go with... I'll stick LinuxCNC (Wheezy as you have linked above) on my PC at home if that what needs to be done... as long as I can stick Vivaldi on the desktop I'm good
Many thanks for responses so far.. b(^_^)
Last edit: 05 Feb 2020 10:28 by fiskrond. Reason: edit
14 Feb 2020 22:38 #157383
Replied by andypugh on topic MXLinux - would this be a good choice?
Late to the party, but I probably wouldn't recommend Wheezy any more.
But, at the same time, I wouldn't use the stuff in linuxcnc.org/temp either, as that is a 64-bit kernel.
So, Maybe a hybrid approach. Install the MX OS on top of the kernel from the Wheezy ISO, if you can. The kernel is a good 32-bit realtime kernel, but the OS (wheezy) is wheezing a bit now.
Time to create page: 0.101 seconds
