upgrading compiled package from master branch 2.9
  • CNCFred
  • CNCFred's Avatar Topic Author
  • Elite Member
  • Elite Member
14 Mar 2020 21:00 - 15 Mar 2020 06:56 #160213 by CNCFred
I installed debian 10 , copied linuxcnc source from github master branch 2.9 and compiled a package which I installed on the same machine.
configured the machine and also plasmac
HOW do I update Linuxcnc and Plasmac on my installation? sources.list has no entries of linuxcnc
Do I need to compile a new updated source download ?
Last edit: 15 Mar 2020 06:56 by CNCFred.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
15 Mar 2020 00:44 #160240 by BeagleBrainz
Replied by BeagleBrainz on topic upgrading compiled package from master branch 2.9
What version are you hoping to upgrade to ?
Master/2.9 is the development version
2.8 is being stabilised for the next release
2.7 is the current stable realese.
3.0 is but a glint in someone's eye.
Here's the buildbot page.
buildbot.linuxcnc.org/
The latest buildbot packages are here
buildbot.linuxcnc.org/dists/buster/maste...reempt/binary-amd64/
  • CNCFred
  • Elite Member
  • Elite Member
15 Mar 2020 06:54 - 15 Mar 2020 06:57 #160256 by CNCFred
Upgrade.... Sorry Update! My bad....changed the topic title too!
Slightly changes were ade in the meantime...
Last edit: 15 Mar 2020 06:57 by CNCFred.
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 07:20 #160259 by BeagleBrainz
The buildbot link I gave has the info required. Read that.
Tho I would be cautious about updating, especially the dev version, without fully investigating the changes made. Personally I would stick with the version you have and get that running smoothly before updating.
  • CNCFred
  • Elite Member
  • Elite Member
15 Mar 2020 08:12 #160264 by CNCFred
I read the buildbot already and used the signing key.
Was not quite sure if that should work for my self made Deb package.
Your advice is appreciated and I will do so!
  • BeagleBrainz
  • Visitor
  • Visitor
15 Mar 2020 09:54 #160272 by BeagleBrainz
If you search the options for apt or apt-get you can force the installation of a particular package version.
sudo apt-get install <package name>=<version>
But I would implore you read a bit more on the usage of apt & apt-get for your own benefit, anything to do with installing packages is the same with debian. I find every so often I have to do a quick search if I haven't used apt for a while or need to do "something a bit funky".
Time to create page: 0.105 seconds
