Cannot change Time in Linux cnc Wheezy 2.7
- Dinuka_Shehan
- Thank you received: 26
17 Mar 2020 03:04 #160502
by Dinuka_Shehan
Cannot change Time in Linux cnc Wheezy 2.7 was created by Dinuka_Shehan
Cannot change Time in Linux cnc Wheezy 2.7.
so unable to connect internet and fail to download new updates.
can you solve this.
I choose Asia local time when installing.
should I install latest version or reinstall using US time frame may resolve the problem?
can you solve this.
- BeagleBrainz
- Visitor
17 Mar 2020 04:08 #160506
by BeagleBrainz
Replied by BeagleBrainz on topic Cannot change Time in Linux cnc Wheezy 2.7
setting time
wiki.debian.org/DateTime
You maybe pointing to wrong repos
wiki.debian.org/DebianWheezy
- Dinuka_Shehan
17 Mar 2020 04:49 - 17 Mar 2020 04:54 #160507
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Cannot change Time in Linux cnc Wheezy 2.7
Set the time manually
When setting the system time manually using date directly, the required time specification format may be confusing (by POSIX convention has to be MMDDhhmmYYYY). However, when using the --set argument date accepts the date and time in many formats. You can read the man page of date, or use the example below for one possible and very useful format. The --set argument examples below is specified in the ISO 8601 standard's extended format as YYYY-MM-DD for Year-Month-DayOfMonth, and time of day HH:MM:SS using 24 hour clock. Leading zeros are significant.
date --set 1998-11-02
date --set 21:08:00
when type this code in terminal
date --set 2020-03-17
date --set 10:25:00
this message receive
date: cannot set date: Operation not permitted
date --set 21:08:00
date --set 10:25:00
Last edit: 17 Mar 2020 04:54 by Dinuka_Shehan.
- BeagleBrainz
- Visitor
17 Mar 2020 05:12 #160508
by BeagleBrainz
try sudo date --set blahblahblahblah
- Dinuka_Shehan
17 Mar 2020 07:38 #160515
by Dinuka_Shehan
sudo date --set 2020-03-17
sudo date --set 12:26:00
success
thank you BeaglrBrainz
can you help on ngcgui problem?
success
- bbsr_5a
- Thank you received: 106
18 Mar 2020 07:31 #160625
by bbsr_5a
Replied by bbsr_5a on topic Cannot change Time in Linux cnc Wheezy 2.7
there is a international standard
this is not used for many countries but it is better to keep it and inform user to type in like YYMMDD
or give a Example in textview that is Clear 2020-03-18 Where day is above 12
- Dinuka_Shehan
18 Mar 2020 15:56 #160649
by Dinuka_Shehan
Is for time change
Is for time change
- BeagleBrainz
- Visitor
18 Mar 2020 16:40 #160659
by BeagleBrainz
Why didn’t you give a clear example of what you meant ?
Old Mate knew what I meant and got it done.
Time to create page: 0.117 seconds
