The Road to Building a real-time (RT) kernel for my favorite OS, Ubuntu 18.04.4
  • clunc
  • clunc's Avatar Topic Author
  • Elite Member
  • Elite Member
29 Mar 2020 01:49 - 29 Mar 2020 01:56 #161903 by clunc
Thanks Andy. I did look at it from the earlier post, but the appearance on my monitor didn't show the file-types and I erroneously concluded from the 'image' in the filename that it was another .iso file. [Edit: returning to that site I remember that I didn't find an RT-Preempt version and concluded I'd have to look elsewhere.]
@BeagleBrainz
You'd probably agree that 'make deb-pkg' is more sophisticated than 'make install' and possibly with the observation that even children have to walk before they can run. I regret that I've offended you.
Last edit: 29 Mar 2020 01:56 by clunc. Reason: update
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
29 Mar 2020 01:55 #161904 by BeagleBrainz
Hey Andy I noticed something weird, I've downloaded the linux-headers package and linux-image package from www.linuxcnc.org/temp and both seem to be a kernel package, am I going mad or are there gremlins about.
Clunc.
Those packages wont work with lubuntu.......now I do have some precompiled packages that will work with lubuntu bionic beaver ie 18.04. Give us a few minutes and I'll pop them onto my google drive and post the links and instructions.
Be Right Back
  • BeagleBrainz
  • Visitor
  • Visitor
29 Mar 2020 02:11 - 29 Mar 2020 02:20 #161905 by BeagleBrainz
OK
Download all the files here, these are the ones I use for the Mint images.
drive.google.com/open?id=18NYefTXp2yQL_8_A9sA3KWB4wu_B8zGi
Once that is done run this command:
sudo apt-get install ./linux-image-4.14.174-rtai-amd64_4.14.174-rtai-amd64-1_amd64.deb \
./linux-headers-4.14.174-rtai-amd64_4.14.174-rtai-amd64-1_amd64.deb \
./rtai-modules-4.14.174_5.2.3-linuxcnc_amd64.deb \
./linuxcnc_2.8.0~pre1~rmurphy.htmldocs~1c3c94442_amd64.deb \
./linuxcnc-dev_2.8.0~pre1~rmurphy.htmldocs~1c3c94442_amd64.deb \
./linuxcnc-doc-en_2.8.0~pre1~rmurphy.htmldocs~1c3c94442_all.deb \
./linuxcnc-doc-html_2.8.0~pre1~rmurphy.htmldocs~1c3c94442_all.deb
Then as super user edit /etc/default/grub
At the beginning of the file make sure that the following lines have the following values
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
More info here www.gnu.org/software/grub/manual/grub/ht...e-configuration.html
Then run
sudo update-grub
Before rebooting read this forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=170#161780 and follow the first link in Adam's first post.
When you reboot you will need to select Advanced Options and pick the line with the rtai kernel.
Last edit: 29 Mar 2020 02:20 by BeagleBrainz.
  • clunc
  • Elite Member
  • Elite Member
29 Mar 2020 15:15 #161978 by clunc
@BeagleBrainz
I downloaded and installed your extensive work on my behalf. Thank you. I sure didn't expect that.
I found the new 4.14.174-rtai kernel at boot (my grub was already set up to allow selecting among kernels) and it booted perfectly fine--and quickly too. No long delay as mentioned in the referenced link. The big surprise was that it booted into straight Ubuntu 18; from the context I was expecting to see Mint (which in fact I still have never seen).
When I started linuxcnc from the command line and picked my config, it warned me that it was out-of-date (2.7) for use with 2.8~pre1 and offered to fix it which I allowed. I noted in the diff that it the new version had [JOINT_n] sections in addition to [AXIS_n], no doubt among others.
After the fix succeeded, again starting LinuxCNC from the command line, the splash screen for 2.8 appears for 5 sec, but nothing happens afterwards. No GUI starts up.
Interrupting with Ctrl-C and restarting linuxcnc warns that "LinuxCNC is still running. Do you want to restart it?" A "Yes" only rails with the information that the RT module is already installed. Attempts to get back to that pre-insmod state, with 'rmmod rtai_sched rtai_hal' are rejected because they are reported to be "in use."
I'm not expecting you to devote any more time to help me resolve my one-of system, but I did caught the results of 'linuxcnc -d -v' and thought you might be curious.
I'm going to take a look at your Mint 19 install, for which work, thanks in advance.
  • BeagleBrainz
  • Visitor
  • Visitor
29 Mar 2020 15:26 - 29 Mar 2020 15:29 #161980 by BeagleBrainz
Could you try running one of the sims say axis and see how long it takes to load up ?
I only did a quick test in a virtual machine to verify that it would install and load one of the simulation configs.
Did you try a latency test to see what figures you got ?
It’s only the kernel you installed not Mint itself ;)
Last edit: 29 Mar 2020 15:29 by BeagleBrainz.
29 Mar 2020 15:38 #161982 by andypugh
The RTAI version of LinuxCNC logs to the kernel log. Can you show us the output of dmesg too?
  • BeagleBrainz
  • Visitor
  • Visitor
29 Mar 2020 15:43 #161983 by BeagleBrainz
Andy did you see my previous message regarding your header package seemingly being the kernel image package ?
  • clunc
  • Elite Member
  • Elite Member
29 Mar 2020 15:45 #161984 by clunc
Dmesg output attached.
@BeagleBrainz
I knew I still hadn't seen Mint. :^)
  • clunc
  • Elite Member
  • Elite Member
29 Mar 2020 15:48 #161985 by clunc
Incidentally, when I looked at your latest Mint 19.2 offerings I saw UEFI in the file names. My old HP machine is running a conventional earth BIOS, as in not designed by Martians. Does that mean those ISOs don't have a chance installing?
29 Mar 2020 16:12 #161986 by andypugh
No, I missed that.
dpkg-scanpackages agrees. How odd. I am trying another build to see what it going on.
Time to create page: 0.280 seconds
