Success: Install LinuxCNC-sim on debian butster?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
07 Apr 2020 17:24 #163108 by BeagleBrainz
Replied by BeagleBrainz on topic Install LinuxCNC-sim on debian butster?
Try
debian/configure uspace noauto
09 Apr 2020 13:12 #163377 by mane
Replied by mane on topic Install LinuxCNC-sim on debian butster?
./configure uspace noauto gives me an output, seems to nothing happened.
manfred@desktop-buero:~/linuxcnc-dev/debian$ ./configure uspace noauto
configure: Set up debian/ files to build for a particular kernel
Usage:
    configure uspace
        Build for a userspace realtime systems or simulator
    configure sim
        Deprecated synonym for 'configure uspace'
    configure [kernel-version]
        Build for the installed RTAI realtime kernel specified by
        [kernel-version], for example "3.4.9-rtai-686-pae"
    configure -r
        Build for the currently running kernel for RTAI realtime only
    configure -a
        If the currently running kernel has realtime extensions, use it.
        Otherwise use any available realtime kernel it can find.
If i try ./configure uspace it seems to be correct working.
successfully configured for 'uspace-Debian-10'-'uspace'..
Then i check the dependencies
manfred@desktop-buero:~/linuxcnc-dev$ dpkg-checkbuilddeps
Started the bulding process
manfred@desktop-buero:~$ dpkg-buildpackage -b -uc
Got some deb packages and install with dpkg -i writes a not configured dependecy failure.
But linuxcnc did was install and the menu is there. Started again by terminal but after chosing a configuration i get a error message.
manfred@desktop-buero:~$ linuxcnc
LINUXCNC - 2.7.15
Machine configuration directory is '/home/manfred/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
/usr/bin/linuxcnc: Zeile 711: /etc/init.d/realtime: Datei oder Verzeichnis nicht gefunden
Realtime system did not load
/usr/bin/linuxcnc: Zeile 606: /etc/init.d/realtime: Datei oder Verzeichnis nicht gefunden
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/manfred/linuxcnc_debug.txt
and
    /home/manfred/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Again not successful.
  • BeagleBrainz
  • Visitor
  • Visitor
09 Apr 2020 13:40 #163380 by BeagleBrainz
What dependency were you missing ?
I’ve built 2.9 for buster with no issues and it’s ran fine. Tho I can’t say if I’ve tried 2.7.
09 Apr 2020 14:03 - 09 Apr 2020 14:04 #163381 by mane
dpkg-checkbuilddeps shows nothing is missing. I assume the not existing realtime is the problem. But as simulation it should not be necessary. This is what i posted today.
I can try to build another version 2.8 or 2.9
Last edit: 09 Apr 2020 14:04 by mane.
  • BeagleBrainz
  • Visitor
  • Visitor
09 Apr 2020 17:19 #163399 by BeagleBrainz
What are the messages from when you try to install linuxcnc ? You mentioned a dependency issue.
09 Apr 2020 17:38 #163400 by PCW
Replied by PCW on topic Install LinuxCNC-sim on debian butster?
Can you post the results of
linuxcnc_info
10 Apr 2020 02:36 - 10 Apr 2020 02:37 #163456 by mane
@BeagleBrainz
Message by installing linuxcnc deb package i posted here.
forum.linuxcnc.org/9-installing-linuxcnc...ster?start=10#163377
@PCW
I can find linuxcnc_info at /usr/bin/linuxcnc_info, content is
manfred@desktop-buero:~$ cat -A /usr/bin/linuxcnc_info
#!/bin/bash$
# This script creates a file in /tmp and$
# opens it with first visual editor found in a search list for editors$
# Copyright: 2014$
# Author:    Dewey Garrett <dgarrett@panix.com>$
# This program is free software; you can redistribute it and/or modify$
# it under the terms of the GNU General Public License as published by$
# the Free Software Foundation; either version 2 of the License, or$
# (at your option) any later version.$
# This program is distributed in the hope that it will be useful,$
# but WITHOUT ANY WARRANTY; without even the implied warranty of$
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the$
# GNU General Public License for more details.$
# You should have received a copy of the GNU General Public License$
# along with this program; if not, write to the Free Software$
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA$
ofile=/tmp/linuxcnc.info$
# all output$
exec 1>$ofile$
exec 2>&1$
# try to find a visual editor to show created file$
# use list with existing preference first, then other common editors$
editors="$VISUAL gedit mousepad geany nedit gvim abiword"$
for e in $editors ; do$
  if [  -x "$(which $e)" ] ; then$
    VIEWER=$e$
    break #use first editor found$
  fi$
done$
function show () {$
  if [ -z "$1" ] ; then$
    echo$
    return$
  fi$
  name=$1$
  shift$
  value=$*$
  printf "%20s: %s\n" "$name" "$value"$
function parse_cpuinfo () {$
  cat /proc/cpuinfo|grep "$1"|head -1|cut -d: -f2-$
function parse_after_colon () {$
  echo "$*"|cut -d: -f2-$
function tryversion () {$
  prog="$1"$
  if [ $(which "$prog") ] ; then$
     ans=$($prog --version 2>/dev/null)$
     if [ -z "$ans" ] ; then$
       echo "?"$
     else$
       echo "$ans"$
     fi$
  else$
     echo "not_in_PATH"$
  fi$
cat <<EOF$
This file can be posted to a web site like:$
     http://pastebin.com$
in order to provide information about the linuxcnc$
system and configuration.$
EOF$
echo VIEWER=$VIEWER$
show "            Date" $(date)$
show "        UTC Date" $(date -u)$
show "    this program" $0$
show "          uptime" $(uptime)$
show " lsb_release -sa" $(lsb_release -sa 2>/dev/null)$
show "  which linuxcnc" $(which linuxcnc)$
show "             pwd" $(pwd -P)$
show "            USER" $USER$
show "         LOGNAME" $LOGNAME$
show "            HOME" $HOME$
show "          EDITOR" $EDITOR$
show "          VISUAL" $VISUAL$
show "        LANGUAGE" $LANGUAGE$
show "            TERM" $TERM$
show "       COLORTERM" $COLORTERM$
show "         DISPLAY" $DISPLAY$
show "    display size" $(parse_after_colon $(xdpyinfo|grep dimensions))$
echo$
echo "uname items:"$
show "     nodename -n" $(uname -n)$
show "  kernel-name -s" $(uname -s)$
show "  kernel-vers -v" $(uname -v)$
show "      machine -k" $(uname -n)$
show "    processor -p" $(uname -p)$
show "     platform -i" $(uname -i)$
show "  oper system -o" $(uname -o)$
show ""$
echo "/proc items:"$
show "         cmdline" $(< /proc/cmdline)$
show "      model name" $(parse_cpuinfo "model name")$
show "           cores" $(parse_cpuinfo "cpu cores")$
show "         cpu MHz" $(parse_cpuinfo "cpu MHz")$
show "         parport" $(cat /proc/ioports|grep parport)$
show "          serial" $(cat /proc/ioports|grep serial)$
echo$
echo "Varsions:"$
show "             gcc" $(gcc --version|head -1)$
show "          python" $(python --version 2>&1)$
show "             git" $(git --version)$
show "             tcl" $(echo "puts $::tcl_version"|tclsh)$
show "              tk" $(echo "puts $::tk_version;destroy ."|wish)$
show "           glade" $(tryversion glade)$
show "      glade-gtk2" $(tryversion glade-gtk2)$
echo$
echo "linuxcnc_var all:"$
echo$
for n in $(linuxcnc_var all) ; do$
   show "${n%%=*}" ${n##*=}$
done$
[ -n $VIEWER ] && $VIEWER "$ofile"$
Last edit: 10 Apr 2020 02:37 by mane.
  • BeagleBrainz
  • Visitor
  • Visitor
10 Apr 2020 05:06 #163466 by BeagleBrainz
I think what was requested was the output of linuxcnc_info
I was asking what was the dependency that was mentioned by dpkg -i .
If there are missing dependencies the installation of the package is incomplete.
10 Apr 2020 08:44 #163480 by mane
Sorry, i did not knew exactly what was meant by providing the linuxcnc_info. Now i executed as command in terminal, see attachment.
And this is the message by installing the deb package. Sorry, most is in german language
It says some packages are missing:
- python-gtksourceview2, python-vte,(not availabe at debian buster
- python-gst-1.0 was missing, is now installed.
Maybe newer linuxcnc versions dont have these dependencies any more?
manfred@desktop-buero:~$ sudo dpkg -i linuxcnc-uspace_2.7.15_amd64.deb
[sudo] Passwort für manfred:
Vormals nicht ausgewähltes Paket linuxcnc-uspace wird gewählt.
(Lese Datenbank ... 208567 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von linuxcnc-uspace_2.7.15_amd64.deb ...
Entpacken von linuxcnc-uspace (1:2.7.15) ...
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linuxcnc-uspace:
 linuxcnc-uspace hängt ab von python-gtksourceview2; aber:
  Paket python-gtksourceview2 ist nicht installiert.
 linuxcnc-uspace hängt ab von python-vte; aber:
  Paket python-vte ist nicht installiert.
 linuxcnc-uspace hängt ab von python-gst-1.0; aber:
  Paket python-gst-1.0 ist nicht installiert.
dpkg: Fehler beim Bearbeiten des Paketes linuxcnc-uspace (--install):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
Trigger für libc-bin (2.28-10) werden verarbeitet ...
Trigger für systemd (241-7~deb10u3) werden verarbeitet ...
Trigger für bamfdaemon (0.5.4-1) werden verarbeitet ...
Rebuilding /usr/share/applications/bamf-2.index...
Trigger für desktop-file-utils (0.23-4) werden verarbeitet ...
Trigger für mime-support (3.62) werden verarbeitet ...
Trigger für man-db (2.8.5-2) werden verarbeitet ...
Trigger für shared-mime-info (1.10-1) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
 linuxcnc-uspace
  • BeagleBrainz
  • Visitor
  • Visitor
10 Apr 2020 12:55 #163516 by BeagleBrainz
I just saw that there is a branch of 2.7 for buster on git.
Maybe that might be better to build from for buster.
Once it is morning here I will give it a go. And if it works I can share the packages with you.
Rob
Time to create page: 0.607 seconds
