Missing hal_vti in build
- cptnmidnight
- Topic Author
6 years 6 months ago #163528
by cptnmidnight
Missing hal_vti in build was created by cptnmidnight
How do I build drivers?
I have been working on a new build to convert a lathe from mdsi to linuxcnc. I have spent days trying to figure out the build system for linuxcnc. I do have many years experience in linux.
This is the specs:
Linux 4.9.0-12-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.210-1 (2020-01-20) x86_64 GNU/Linux
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
linuxcnc 2.9.0~pre0 (fresh git pull)
Tried building both RIP and deb with uspace option.
I end up with a mostly working linuxcnc in both cases. I do NOT get a driver for hal_vti.
Output:
hal_vti.h and hal_vti.c are included in the source code but do not build or install
This is the specs:
Output:
Found file(REL): ./vti_motion.hal
hal_vti: dlopen: /usr/lib/linuxcnc/modules/hal_vti.so: cannot open shared object file: No such file or directory
./vti_motion.hal:6: waitpid failed /usr/bin/rtapi_app hal_vti
./vti_motion.hal:6: /usr/bin/rtapi_app exited without becoming ready
./vti_motion.hal:6: insmod for hal_vti failed, returned -1
/linuxcnc-dev/src/hal/drivers$ ls
bcm2835.h hal_ax5214h.c hal_parport.c hal_speaker.c hal_vti.h opto_ac5.c pluto_servo.comp serport.comp
beaglebone_gpio.h hal_bb_gpio.c hal_pi_gpio.c hal_stg.c mesa_7i65.comp opto_ac5.h pluto_servo_firmware Submakefile
cpuinfo.c hal_evoreg.c hal_pi_gpio_demo.hal hal_stg.h mesa-hostmot2 pci_8255.c pluto_step.comp
cpuinfo.h hal_gm.c hal_ppmc.c hal_tiro.c mesa_uart.comp pcl720.comp pluto_step_firmware
gm.h hal_motenc.c hal_skeleton.c hal_vti.c motenc.h pluto_common.h rbf2h.py
halcmd: loadrt
Display all 164 possibilities? (y or n)
5axiskins conv_bit_u32 gantry joyhandle mult2 sampler thcud
abs conv_float_s32 gearchange knob2float multiclick scale threads
abs_s32 conv_float_u32 genhexkins latencybins multiswitch scarakins threadtest
and2 conv_s32_bit genserkins lcd mux16 scope_rt time
at_pid conv_s32_float gray2bin limit1 mux2 scorbot-kins timedelay
axistest conv_s32_u32 hal_bb_gpio limit2 mux4 select8 timedelta
bin2gray conv_u32_bit hal_gm limit3 mux8 serport toggle
biquad conv_u32_float hal_lib lincurve mux_generic setsserial toggle2nist
bitslice conv_u32_s32 hal_parport lineardeltakins near siggen tripodkins
bitwise corexy_by_hal hal_pi_gpio logic not sim_axis_hardware tristate_bit
bldc corexykins hal_ppmc lowpass offset sim_encoder tristate_float
bldc_hall3 counter histobins lut5 ohmic sim_home_switch trivkins
blend ddt hm2_7i43 maj3 oneshot sim_matrix_kb updown
boss_plc deadzone hm2_7i90 match8 or2 sim_parport watchdog
carousel debounce hm2_eth matrix_kb orient sim_spindle wcomp
charge_pump demux hm2_pci max31855 pentakins simple_tp weighted_sum
clarke2 differential hm2_rpspi maxkins pid sphereprobe xhc_hb04_util
clarke3 edge hm2_spi mesa_7i65 plasmac spindle_monitor xor2
clarkeinv encoder hm2_test mesa_pktgyro_test pumakins stepgen xyzac-trt-kins
classicladder_rt encoder_ratio hostmot2 message pwmgen steptest xyzbc-trt-kins
comp eoffset_per_angle hypot minmax rosekins streamer
constant estop_latch ilowpass modmath rotarydeltakins sum2
conv_bit_float feedcomp integ motmod rotatekins supply
conv_bit_s32 flipflop invert moveoff sample_hold thc
- scotta
- Thank you received: 489
6 years 6 months ago #163537
by scotta
Replied by scotta on topic Missing hal_vti in build
You can always manually install using halcompile.
/linuxcnc-dev/src/hal/drivers$ halcompile --install hal_vti.c
- cptnmidnight
- Topic Author
6 years 6 months ago - 6 years 6 months ago #163551
by cptnmidnight
Replied by cptnmidnight on topic Missing hal_vti in build
Sorry, I left out that I had tried that already. Halcompile does not seem to know where to find the kernel headers. I get a failure with asm/io.h not found
I do have the headers installed, I've been playing with symlinks and folder names just can't quite get this to work.
Compiling realtime hal_vti.c
hal_vti.c:155:20: fatal error: asm/io.h: No such file or directory
#include <asm/io.h>
compilation terminated.
/usr/share/linuxcnc/Makefile.modinc:113: recipe for target 'hal_vti.o' failed
make: *** [hal_vti.o] Error 1
find /usr/src/ -iname io.h
/usr/src/linux-headers-4.9.0-12-common-rt/arch/x86/include/asm/io.h
/usr/src/linux-headers-4.9.0-12-common-rt/include/linux/io.h
/usr/src/linux-headers-4.9.0-12-common-rt/include/asm/io.h
/usr/src/linux-headers-4.9.0-12-rt-amd64/include/config/generic/io.h
/usr/src/linux-headers-4.9.0-12-rt-amd64/include/config/fb/deferred/io.h
Last edit: 6 years 6 months ago by cptnmidnight.
- cptnmidnight
- Topic Author
6 years 6 months ago - 6 years 6 months ago #164380
by cptnmidnight
I found an old iso running version 2.5 32 bit. The hal loads but appears the expansion boards are not supported. Guess I will be dumping this controller and moving on to a centroid oak.
Edit:
This has nothing to do with linuxcnc's lack of support for antique, exotic, and rare hardware, I just hoped to be able to use the existing hardware in this lathe. Since it is so bloody old and unsupported, I have to replace the hardware.
I could try justify spending thousands on linuxcnc compatible hardware and spend weeks learning how to make that work or go with Centroid OAK or AIO and be up and running in hours.
I don't want to appear ungrateful, I just don't have the programming talent to write drivers that I would trust in a production system worth hundreds of thousands.
Edit:
Last edit: 6 years 6 months ago by cptnmidnight. Reason: Original post might have sounded a little pithy
Time to create page: 0.078 seconds
