Installation problems with SSD
6 years 6 months ago #165597 by PortlandGTS
BeagleBrainz wrote: Just beware that UEFI booting with a RTAI kernel will only detect a single core. So effectively a 2/4/6 core CPU will end as a single core system.
Thanks for pointing that out. That's good to know.
tom
6 years 6 months ago #165600 by tommylight
PortlandGTS wrote: I'll probably go with clonezilla, but wheezy's getting kind of old, so let me double check: RT-preempt has low enough latency to work with Mesa boards, correct? RTAI is only needed for direct motor control?
Tom
Yes Tom, RT has very good latency for Mesa boards, and can also do parallel port or direct motor drive control, on newish PC's. RTAI is better for older PC's.
I have RT on two core2duo PC's and the latency is low enough to use parallel comfortably, one of them has another add on PCI parallel card and a Mesa 6i25 in it, so it total it has 4 D25 connectors on the back.
Tom
Time to create page: 0.041 seconds
