Installation problems with SSD
25 Apr 2020 19:29 #165570 by PortlandGTS
Installation problems with SSD was created by PortlandGTS
I've been running LinuxCNC 2.8 on wheezy with RTAI kernel for several years now. I'm running into problems trying to upgrade to an SSD with more capacity and a separate /home partition.
I downloaded the latest Master .iso and loaded it onto a USB stick. Then I found that legacy boot doesn't work on my system. (Motherboard is a Gigabyte GA-Z77-UD5H). Don't remember how I did it before, but I probably used a CD-ROM drive. That's long gone, and I don't even have a CD burner to write an iso to CD-ROM.
Then I tried installing the LinuxCNC .iso from a hard drive. I tried various HD-media Debian installers, but they would not accept the LinuxCNC .iso. Apparently the kernel in the installer must be the same version as the kernel in the .iso. Anybody know how where to get a vmlinuz with right RTAI kernel?
Not sure where to go from here. I've spent a lot of time going down dead ends, and don't want to go down another. The only two choices I can see right now are HW changes (CD-burner or new motherboard), or a switch to Debian 9 or 10 with a preempt kernel.
Anybody have any other suggestions before I start down one of those paths?
Thanks,
Tom
25 Apr 2020 20:19 #165572 by Mike_Eitel
Replied by Mike_Eitel on topic Installation problems with SSD
I did it with clonezilla
But here are a choice of tools described.
www.ubuntupit.com/top-15-best-disk-cloning-software-for-linux/
Mike
  • Moderator
  • Moderator
25 Apr 2020 20:32 #165574 by tommylight
Replied by tommylight on topic Installation problems with SSD
You can give these a try:
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
For Debian 10, and
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
For Mint 19.x
If you do need RTAI, i did successfully install it on Mint 19.2 with the packages downloaded from here:
www.linuxcnc.org/temp
As mike mentioned, clonezilla is a nice way to copy HDD's.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
25 Apr 2020 21:33 #165580 by BeagleBrainz
Replied by BeagleBrainz on topic Installation problems with SSD
Just beware that UEFI booting with a RTAI kernel will only detect a single core. So effectively a 2/4/6 core CPU will end as a single core system.
26 Apr 2020 00:04 #165594 by PortlandGTS
Replied by PortlandGTS on topic Installation problems with SSD
clonezilla looks like it will do the job!
Thanks,Tom
26 Apr 2020 00:11 #165595 by PortlandGTS
For Debian 10, and
For Mint 19.x
I'll probably go with clonezilla, but wheezy's getting kind of old, so let me double check: RT-preempt has low enough latency to work with Mesa boards, correct? RTAI is only needed for direct motor control?
Tom
26 Apr 2020 00:13 #165597 by PortlandGTS
Thanks for pointing that out. That's good to know.
tom
  • Moderator
  • Moderator
26 Apr 2020 00:38 #165600 by tommylight
Tom
Yes Tom, RT has very good latency for Mesa boards, and can also do parallel port or direct motor drive control, on newish PC's. RTAI is better for older PC's.
I have RT on two core2duo PC's and the latency is low enough to use parallel comfortably, one of them has another add on PCI parallel card and a Mesa 6i25 in it, so it total it has 4 D25 connectors on the back.
Tom
Time to create page: 0.108 seconds
