LinuxCNC on Debian 10 Buster quick and easy install
- Thank you received: 7496
17 Apr 2020 18:24 - 05 Mar 2021 21:13 #164287
Please use the official release found here:
linuxcnc.org/downloads/
Use this tutorial only if you have issues with dirvers, be it WiFi or graphic or else, ..
This is the easiest way to get Linuxcnc working on Debian Buster:
--Download the non-free version of Debian as the free version has no proprietary drivers included and may result in non functioning hardware, from here
cdimage.debian.org/images/unofficial/non.../current-live/amd64/
----In case the above link does not work, change the number 4 in the address to 5, where the debian version is. So 10.4.0 becomes 10.5.0 or 10.6.0 etc. Only needed when a new version of Debian is released. Also do please notify us so we can fix the link.
--Choose BT if you have bittorrent client installed or iso-hybrid for normal download
--Write the downloaded ISO to a USB drive using DD in linux or win32imager in windows
--Boot from that USB, make sure the BIOS is set to boot from USB devices, if not repeatedly click on F9 or F11 or F12 as soon as you press the power switch, that should get you the choice of bootable devices, choose USB, not UEFI-USB, if at all possible.
--Let it boot too the desktop, click on "install debian" on the desktop.
--Reboot, remove the USB.
- Method 1:
Download the attachment, unzipping it to your Downloads folder, double click on "install.sh" and choose "run in terminal" . If that does not work then type these lines in terminal:Press Y once when prompted and reboot when finished.
- Method 2:
-Open terminal and copy and paste one by one the following lines:-Reboot
-Enjoy
- For setting up using parallel port, click on "applications" menu on the upper left > cnc > Stepconf Wizard
- For setting up Mesa boards, click on "applications" menu on the upper left > cnc > Pncconf Wizard
Enjoy !
Additional info:
It seems the this Debian has issues with USB WIFI dongles with the Realtek hardware, so in case you see the wireless networks but it will not connect, open a terminal and paste this:
sudo ln -s /dev/null /etc/systemd/network/99-default.link
LinuxCNC on Debian 10 Buster quick and easy install was created by tommylight
- Method 1:
cd Downloads
sudo chmod +x install.sh
./install.sh-
- Method 2:
sudo apt-get update
sudo apt-get -y install gdebi software-properties-common wget linux-headers-4.19.0-9-common-rt linux-headers-4.19.0-9-rt linux-image-4.19.0-9-rt-amd64
wget http://http.us.debian.org/debian/pool/main/p/pygtksourceview/python-gtksourceview2_2.10.1-3_amd64.deb
sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
sudo apt-add-repository 'http://buildbot.linuxcnc.org/ buster master-rtpreempt'
-OR, for 2.8 stable release, not both,
sudo apt-add-repository 'http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt'
sudo apt-get update
sudo apt-get -y install linuxcnc-uspace-Enjoy
Enjoy !
Additional info:
Last edit: 05 Mar 2021 21:13 by tommylight. Reason: updated link
The following user(s) said Thank You: phillc54, chimeno, Clive S, MrFouFou, mkardasi, Arpad, taloot, johnmc1, zack, CORBETT and 6 other people also said thanks.
- bbsr_5a
- Thank you received: 106
18 Apr 2020 08:37 #164429
by bbsr_5a
Replied by bbsr_5a on topic LinuxCNC on Debian 10 Buster quick and easy install
Thanks you
is this image only for USB or can i burn it to DVD also
- BeagleBrainz
- Visitor
18 Apr 2020 10:24 #164436
by BeagleBrainz
Replied by BeagleBrainz on topic LinuxCNC on Debian 10 Buster quick and easy install
Debian images can either be burnt to DVD or dd'd to a USB drive
Good work Tommy
Do you have a link for python-gtksourceview2_2.10.1-3_amd64.deb ?
Good work Tommy
18 Apr 2020 11:25 #164441
Replied by tommylight on topic LinuxCNC on Debian 10 Buster quick and easy install
Yes.Thanks you
18 Apr 2020 11:26 #164442
Forgot your glasses, or to much staring at monitors ?
It is the second link !Do you have a link for python-gtksourceview2_2.10.1-3_amd64.deb ?
The following user(s) said Thank You: BeagleBrainz
- BeagleBrainz
- Visitor
18 Apr 2020 11:57 #164444
by BeagleBrainz
Can't see shit without my specs on a computer screen any more.
Pain killers must be messing with my head.
18 Apr 2020 12:04 #164445
Same here. Getting old is no fun. And i had extremely good vision!Can't see shit without my specs on a computer screen any more.
- bbsr_5a
18 Apr 2020 12:48 #164452
by bbsr_5a
thank you
will this be the start of the new standard
as thinking of stretch renewed
or is it the same a sideway to go beside mint
18 Apr 2020 13:52 #164458
This is more to prove that getting Linuxcnc is simple and can be done in 20 to 30 minutes flat.
I read everything on this forum and i am getting tired of seeing new users being advised to compile Linuxcnc and kernels to make it work, also building "run in place" Linuxcnc ! Those are for developers and tinkerers and people who have some knowledge of inner workings of Linux and Linuxcnc.
New users want to have a running machine as fast as possible, not spend days compiling.
The following user(s) said Thank You: Mike_Eitel, phillc54, Clive S, CORBETT
18 Apr 2020 14:06 #164459
Edited original post to use official Debian Buster kernel.
Makes it even simpler to install.
Time to create page: 0.635 seconds
