LinuxCNC on Debian 10 Buster quick and easy install
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
07 Aug 2020 12:53 #177611 by tommylight
linuxcnc.org/temp/2.8_test4.iso
(Installs Buster and a buildbot version of LinuxCNC 2.8)
This is 99% of what the official 2.8 release will be, so feedback appreciated.
Note that the QTVCP configs need extra dependencies, this will be fixed in the final release.
Downloading right now.
07 Aug 2020 12:54 #177612 by andypugh
I installed Buster on two computers, never got asked to set a root password, but Wheezy and Stretch did ask for it so i just left it blank and it always worked.
The LinuxCNC ISO will be set up to not ask (it is pre-seeded to blank in the config)
  • Moderator
  • Moderator
07 Aug 2020 19:27 - 08 Aug 2020 14:24 #177641 by tommylight
Some results of 2.8test4.iso :
-live boot = OK , LinuxCNC runs
-graphical install = OK, does not ask for root password.
Now testing CLI install
Last edit: 08 Aug 2020 14:24 by tommylight. Reason: cganged content after some more testing.
  • Moderator
  • Moderator
07 Aug 2020 19:59 - 08 Aug 2020 14:25 #177647 by tommylight
CLI install works, does not ask for root.
Tested on 2 PC's.
Last edit: 08 Aug 2020 14:25 by tommylight. Reason: cganged content after some more testing.
07 Aug 2020 22:04 #177661 by andypugh
That's weird. And frankly I don't know what I can do about that, as this is only a slightly-tweaked standard Debian installer.
07 Aug 2020 22:07 #177662 by Clive S
I am just downloading it now so will try it in the morning and report back
  • Moderator
  • Moderator
07 Aug 2020 22:35 #177664 by tommylight
Had such issues multiple times before with Debian, from wheezy and up.
More testing tomorrow, had some people here till late.
08 Aug 2020 00:37 #177671 by phillc54
I have installed the test ISO on a Vmware VM and also a bare metal machine and it worked fine.
On the bare metal I uninstalled LinuxCNC the changed the repo to the Buildbot then installed LinuxCNC again. All the sims I tried worked including some Qtvcp ones.
The only minor issue I found was that I needed to enter my WiFi details after the first boot as they weren't saved.
08 Aug 2020 09:32 - 08 Aug 2020 10:04 #177677 by Clive S
I used Ethcher to make the USB stick.
Live install works as expected and can ping my Naz from it.
Graphical install hung at configure network . about 3 mins in
Install hung at configure network . about 3 mins in
Then I tried unplugging the network cable then it let me carry on when it got to the DHCP stuff .
I re-plugged the network cable and it all went fine and installed completely
Edit: It does not recognise my usb dongle that has worked on all previous installs
And things like screen shot seem to be missing. Also I did not see an option for auto login
Last edit: 08 Aug 2020 10:04 by Clive S.
  • Moderator
  • Moderator
08 Aug 2020 14:27 - 08 Aug 2020 14:28 #177685 by tommylight
Tested with another USB stick, everything works properly and does not ask for root password.
-Taking screenshots should be on the accessories menu,
-If having trouble with WiFi, check the first post.
P.S.
Also edited the above posts to reflect the current results.
Last edit: 08 Aug 2020 14:28 by tommylight. Reason: More info
Time to create page: 0.233 seconds
