LinuxCNC on Debian 10 Buster quick and easy install
10 May 2020 19:55 #167299 by jeffmaxwell
Replied by jeffmaxwell on topic LinuxCNC on Debian 10 Buster quick and easy install
The following link from your first post does not work--I want to try installing linux cnc this way but I cant download the first image. Help?
Jeff
--Download the non-free version of Debian as the free version has no proprietary drivers included and may result in non functioning hardware, from here
cdimage.debian.org/images/unofficial/non...-live+nonfree/amd64/
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
10 May 2020 20:10 #167300 by tommylight
Link edited to point to 10.4.
Thank you for reporting that.
Regards,
Tom.
11 May 2020 00:42 #167315 by Plasmaguy
Im trying this route again and running into an issue. I follow the instructions exactly as they are shown.
plaz@plaz-pc:~$ uname -a
Linux plaz-pc 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2 (2020-04-29) x86_64 GNU/Linux
plaz@plaz-pc:~$ cd downloads
bash: cd: downloads: No such file or directory
plaz@plaz-pc:~$ cd Downloads
plaz@plaz-pc:~/Downloads$ sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
[sudo] password for plaz:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Python bindings for the GtkSourceView widget
GtkSourceView is a text widget that extends the standard GTK+ 2.x text
widget GtkTextView. It improves GtkTextView by implementing syntax
highlighting and other features typical of a source editor.
This package contains the Python bindings for GtkSourceView, and allows
to write Python programs that use the GtkSourceView widget.
Do you want to install the software package? [y/N]:y
/usr/bin/gdebi:113: FutureWarning: Possible nested set at position 1
c = findall("[[(](\S+)/\S+[])]", msg)[0].lower()
(Reading database ... 310448 files and directories currently installed.)
Preparing to unpack python-gtksourceview2_2.10.1-3_amd64.deb ...
Unpacking python-gtksourceview2 (2.10.1-3) over (2.10.1-3) ...
Setting up python-gtksourceview2 (2.10.1-3) ...
plaz@plaz-pc:~/Downloads$ sudo gdebi linuxcnc-uspace_2.9.0~pre0.1456.gdb3a15891_amd64.deb
Failed to open the software package
The package might be corrupted or you are not allowed to open the file. Check the permissions of the file.
11 May 2020 04:54 #167327 by matthewsx
I'm getting a 404 not found for the buildbot links
11 May 2020 05:50 #167330 by Plasmaguy
You should be able to right-click the link and save as.
  • Moderator
  • Moderator
11 May 2020 08:01 #167342 by tommylight
Download that file again, it is corrupted or the download broke.
  • Moderator
  • Moderator
11 May 2020 08:02 #167343 by tommylight
All working now.
11 May 2020 14:10 #167375 by Plasmaguy
I tried again several times and it fails.
  • Moderator
  • Moderator
11 May 2020 14:47 #167378 by tommylight
You have the wrong kernel installed,
I did several installations of this, it always works, always.
Can you please try one more time, and keep track of the steps so when you get stuck post that here.
Thank you.
11 May 2020 14:49 - 11 May 2020 17:24 #167379 by Plasmaguy
How would the wrong kernel be installed when I follow your instructions exactly as they are set forth?
This is neither quick nor easy if it repeatedly gives corrupted files and others are also having problems getting your instructions here to work.
I tried on two different machines.
Last edit: 11 May 2020 17:24 by Plasmaguy.
Time to create page: 0.306 seconds
