LinuxCNC on Debian 10 Buster quick and easy install
- BeagleBrainz
- Visitor
10 Oct 2020 03:19 #185565
by BeagleBrainz
What are you saying here ? I don't quite get what you are hinting at.
Usual process is:
You download the ISO.
You write the ISO to a usb stick. The image must be written to the device, not a partition. Under windows win32diskimager works all the time under normal circumstances. Under Linux & MacOS dd works well, tho you have to be careful.
Your OS may not recognise the format of the disk after this.
Boot with the USB sitck.
Then install onto your system.
If you think the images are damaged the best thing is to check the md5sum.
Also a description on your computer hardware will help. Either the model & brand of the computer or the exact model of motherboard.
Replied by BeagleBrainz on topic LinuxCNC on Debian 10 Buster quick and easy install
And I tried 2 programs to mount iso images and if it mounts well but at the moment of wanting to install it does not recognize the ssd or hdd to install it and I know that it is not my computer because I tried 3 different, I think the images are damaged or Will the programs be used?
What program do you recommend that works?
Or a pre-designed package that you have already used and works that you can share with me.
Usual process is:
- strahlensauger
- Thank you received: 66
23 Oct 2020 03:10 #186982
by strahlensauger
Replied by strahlensauger on topic LinuxCNC on Debian 10 Buster quick and easy install
Hi Tommy,
the link needs to be updated to10.6
- Thank you received: 7505
23 Oct 2020 05:18 #186992
Replied by tommylight on topic LinuxCNC on Debian 10 Buster quick and easy install
Done, thank you.
- hottabich
- Thank you received: 96
25 Nov 2020 12:00 #190278
by hottabich
Replied by hottabich on topic LinuxCNC on Debian 10 Buster quick and easy install
In the first post you recommend the official Linuxcnc Debian Buster.iso image. Disadvantages: during installation
from USB, you need to remove the USB flash drive and insert it into another usb port. XCFE environment does not allow installing GIMP. Gdebi doesn't work ... When adding Mate environment it works better. No built-in designer with widgets.
25 Nov 2020 12:24 #190280
Never had to do that, it works properly on at least 5 of my computers/laptops.Disadvantages: during installation
It does, have it on 2 PC's, simple "sudo apt-get install gimp" worked.XCFE environment does not allow installing GIMP.
It does work, it is used to install stuff in this tutorial.Gdebi doesn't work ...
Yes it does, i use Mate exclusively on my PC's/laptops.When adding Mate environment it works better.
No, they are not included, this is a non-free version of Official Debian Buster with LinuxCNC added, nothing more and nothing less.No built-in designer with widgets.
- hottabich
25 Nov 2020 15:30 #190292
by hottabich
Install official non free Linuxcnc Debian Buster.iso mit linuxcnc.
25 Nov 2020 15:34 - 25 Nov 2020 15:34 #190293
The difference is the non-free version has proprietary drivers that might be needed for some WiFi hardware.
BTW, it says to install official release at the top of the first post.
Official LinuxCNC Debian Buster is not "non free", it is the free version.Install official non free Linuxcnc Debian Buster.iso mit linuxcnc.
Last edit: 25 Nov 2020 15:34 by tommylight. Reason: more info
- DenkBrettl
05 Mar 2021 13:51 #201120
by DenkBrettl
Replied by DenkBrettl on topic LinuxCNC on Debian 10 Buster quick and easy install
I think you could change the link to cdimage.debian.org/images/unofficial/non.../current-live/amd64/ and it would always be current. If not then 10.8 is the current version.
Which desktop environment would you recommend for LinuxCNC? Any differences?
05 Mar 2021 15:14 #201130
Done, thank you.I think you could change the link to cdimage.debian.org/images/unofficial/non.../current-live/amd64/ and it would always be current. If not then 10.8 is the current version.
I prefer Mate, although i use XFCE on older systems. But i use mostly Mint.Which desktop environment would you recommend for LinuxCNC? Any differences?
Time to create page: 0.925 seconds
