LinuxCNC on Debian 10 Buster quick and easy install
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
03 May 2020 17:03 #166518 by tommylight
Probably a silly question but I am upgrading an i386 system from 2.7 to 2.9 in order to run the fancy plasmac config on my plasma gantry. I assume I should download an i386 iso rather than the recommended amd64 link?
What computer ? Anything from the last 10 or more years should be fine with 64 bit versions.
03 May 2020 20:42 #166539 by Plasmaguy
It's a Dell Vostro 220 I bought a few years ago for cheap and has been a workhorse running LCNC v 2.7 since 2017ish.
  • Moderator
  • Moderator
04 May 2020 00:48 #166556 by tommylight
Download the ISO, write it to a USB and try to boot it, it should boot just fine.
The following user(s) said Thank You: Plasmaguy
04 May 2020 04:09 - 04 May 2020 04:09 #166568 by Plasmaguy
I got it to boot and completed through;
cd Downloads
sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
Now at the next point I am getting the message;
plaz@plaz-pc:~/Downloads$ sudo gdebi linuxcnc-uspace_2.8.0~pre1.5649.gec411a428_amd64.deb
gdebi error, file not found: linuxcnc-uspace_2.8.0~pre1.5649.gec411a428_amd64.deb
The required file is located in my download folder along with the one that has already processed, any idea what might be the problem? I have tried both 2.9 & 2.8 versions to the same result.
Last edit: 04 May 2020 04:09 by Plasmaguy.
  • Moderator
  • Moderator
04 May 2020 10:36 #166605 by tommylight
Most probably wrong file name, check the build numbers if they correspond between the downloaded file and the one you are trying to install.
04 May 2020 13:10 - 04 May 2020 13:23 #166617 by Plasmaguy
The numbers seem to match. I only downloaded what was linked in the original post.
I did notice a discrepancy between was comes up when I enter the uname -a command and what is shown in the OP.
plaz@plaz-pc:~$ uname -a
Linux plaz-pc 4.19.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.98-1+deb10u1 (2020-04-27) x86_64 GNU/Linux
vs.
Should say "Linux some_name 4.19.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.98-1 (2020-01-26) x86_64 GNU/Linux
Last edit: 04 May 2020 13:23 by Plasmaguy. Reason: add info
  • Moderator
  • Moderator
04 May 2020 15:06 #166626 by tommylight
That should work, the issue above is due to miss typed name of the file not residing in the Downloads folder.
04 May 2020 17:46 #166645 by Plasmaguy
I'm sorry but I do not understand.
I tried this on another computer with 64 bit system with the same result.
I followed the directions correctly (I think) so what do I need to do to get it working?
  • Moderator
  • Moderator
04 May 2020 18:55 #166657 by tommylight
in terminal
cd Downloads
ls
what does it show ?
04 May 2020 20:18 #166673 by Plasmaguy
I went another way and installed the linux mint you linked to here forum.linuxcnc.org/9-installing-linuxcnc...er-mint-iso?start=10 without any problem.
Thank you!
Time to create page: 0.309 seconds
