Re:Intel D945GCLF2
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Aug 2010 20:16 #3908 by billykid
Intel D945GCLF2 was created by billykid
hello, I read on Wiki Hardware that works "and I saw that Intel D945GCLF2 mini-ITX seems to perform well.
I wanted to know if you can easily install or need to compile EMC2 driver.
Regards Mauro
30 Aug 2010 18:09 #3919 by andypugh
Replied by andypugh on topic Re:Intel D945GCLF2
A Live-CD installation onto fresh hardware should "Just Work"
  • billykid
  • Platinum Member
  • Platinum Member
30 Aug 2010 19:05 #3920 by billykid
Replied by billykid on topic Re:Intel D945GCLF2
I wanted to know if this card has problems getting the onboard video. I wanted to buy it to replace my motherboard that has a very high latency.
thanks
01 Sep 2010 00:31 - 01 Sep 2010 00:36 #3930 by Rturner
Replied by Rturner on topic Re:Intel D945GCLF2
The D945GCLF2 will work with a Live CD install and no modifications (other than setting the parallel port to EPP mode in BIOS). The onboard video plays well with EMC, and it won't require an add-on video card. However, the D945GCLF2 went out of production and is getting impossible to find through primary sellers. The D510MO works also, but you'll need to install Ubuntu 10 then EMC in order to use the on-board ethernet and audio. Once installed this way, everything should work, including the on-board video.
Last edit: 01 Sep 2010 00:36 by Rturner.
01 Sep 2010 10:45 #3936 by BigJohnT
Replied by BigJohnT on topic Re:Intel D945GCLF2
There is an experimental 10.04 LiveCD now somewhere, but I can't find it atm.
01 Sep 2010 11:30 #3940 by andypugh
This is it:
www.linuxcnc.org/mozmck/ubuntu-10.04-linuxcnc1-i386.iso
02 Sep 2010 13:45 #3958 by eai
Replied by eai on topic Re:Intel D945GCLF2
I use it few years.
This board is very nice.
But I have problems if GCode programm has 1 000 000 lines e.t.c. because CPU is slow and we have only 2Gb RAM
This board has not any problems with small and medium files.
  • billykid
  • Platinum Member
  • Platinum Member
02 Sep 2010 18:37 #3966 by billykid
Thank you all! I just bought this card and goes really well.
Regards Mauro
19 Jan 2021 19:28 #195912 by jarcysgru
Replied by jarcysgru on topic Re:Intel D945GCLF2
Witam czy ta płyta Intel D945GCLF2D Atom 330 2x 1,60GHz obsłuży mi linuxcnc 2.7.14 proszę o odpowiedź pozdrawiam i dziekuje.
19 Jan 2021 19:32 #195913 by RotarySMP
Replied by RotarySMP on topic Re:Intel D945GCLF2
I use this Mini-Itx computor as the brain for my Maho. It is not the fastest, but has worked flawlessly with my Mesa Hardware.
Mark
Time to create page: 0.124 seconds
