LinuxCNC will not start. Using MESA 7i76e
6 years 5 months ago #168475 by tommylight
buildbot.linuxcnc.org/
Follow the instructions on that page to update to version 2.8 or 2.9 as 2.7 does not have some features that PlasmaC requires to run properly.
6 years 5 months ago #168651 by turbodude
OK trying to update now.
6 years 5 months ago #168806 by raychar
Hello,
I encounter the same problem. By editing the hal file with 10.10.10.10 network address, still cannot succeed with error information showed on attached file, any help will be appreciated.
6 years 5 months ago - 6 years 5 months ago #168810 by PCW
./my_LinuxCNC_Machine1.hal:1: unknown command ' '
Looks like the first line in the hal file has a non-ASCII character or something
Is it possible you edited the hal file with a word processor instead of a text editor?
Last edit: 6 years 5 months ago by PCW.
6 years 5 months ago #168967 by raychar
Thanks, it works now. However, whenever changes are made through pncconfig wizard, incorrect network address is used again and the correction procedures need to be done again.. Anyway, now the axis-gui page appears. However, in my case the stepper motors don't run. There are no step pulses generated from my Mesa card 7i76e, when I use oscilloscope to measure, none is observed. But I can see the DIR output changes, positive direction move gives 0 volt and negative direction move gives +5V (why it reversed!, I didn't click inv. check box in the configuration)...After closing the axis-gui and going back to pncconfig wizard setting page, when pressing the Test/Tuning axis button, the error message appears as shown in attachment. What problems are there? Anybody can give help and it will be much appreciated.
6 years 5 months ago - 6 years 5 months ago #168974 by PCW
The most common cause for lack of motion (assuming the drives are wired correctly)
is too short step lengths. I would set the step lengths to 5000 and try again.
The test error is related to a kernel version test that is not needed for Preempt-RT
systems. This (and the default step width) are fixed in newer versions of pncconf
Time to create page: 0.198 seconds
