LinuxCNC will not start. Using MESA 7i76e
6 years 5 months ago #168244 by turbodude
I had the jumper set to 10.10.10.10 on the 7i76e (deliberately) well before running the Pncconf wizard. Pncconf seems to just leave it at the default 192.168.1.121.
I checked the 7i76e user manual and it says "Default IP address is always 192.168.1.121" unless you change jumper settings. So at least I know where that address comes from.
I changed the hal file to 10.10.10.10 and now LinuxCNC opens fine. Yay!
Thanks heaps for you quick responses guys. Very much appreciated.
Cheers.
6 years 5 months ago - 6 years 5 months ago #168251 by Clive S
turbodude wrote: Yep, attached. I noticed in the hal file it has that IP address (192.168.1.121). Why would that be? I am still totally new to this.
Yes. you can edit the hal file and change the numbers. (now that you have a config its time to stop using the conf tool as it will overwrite any edits you do)
You could ping it because it was using your other dhcp port. So as Tom has pointed out change the jumper of the 7i76e
Edit: cross posted glad you got it sorted
Last edit: 6 years 5 months ago by Clive S.
6 years 5 months ago #168265 by tommylight
That can be set in pncconf also, it is just under the board model.
ASUS ROG Crosshair VIII Impact - AMD X570
6 years 5 months ago - 6 years 5 months ago #168346 by turbodude
Maybe I am going blind but I can't see it. I have attached a screenshot of where the board model is selected.
Last edit: 6 years 5 months ago by turbodude.
6 years 5 months ago #168353 by tommylight
What version is that?
Here's mine:
6 years 5 months ago #168474 by turbodude
Iam running 2.7.14 from here: I have installed "linuxcnc-stretch-uspace-amd64.iso" from www.linuxcnc.org/testing-stretch-rtpreempt/
I want to run Plasmac (dual router & plasma cutter machine) so this was the recommended version in the documentation.
Time to create page: 0.913 seconds
