Which CNC system to install?
  • TglEMC
  • TglEMC's Avatar Topic Author
  • Senior Member
  • Senior Member
20 May 2020 21:12 #168409 by TglEMC
Which CNC system to install? was created by TglEMC
Hello all. I am working on a Sherline replacement EMC machine. I have had major problems getting the parallel port drivers installed. I am in a place where I can start fresh with a new install. My first question is which CNC OS to install.
I currently have Debian stretch i386 installed but my new machine is an AMD Athlon 64 X2 dual-core processor. I originally used i386 because I have sherline software discs, which is worthless due to the video drivers used in the Ubuntu OS. I would like to use the EMC software from that disk. I have the original i386 deb files intact.
Parallel port card is a single port MCS9865. My best guess at the moment is that I should have tried installing the parallel port drivers before a making any system upgrades.
I plan to install a 64-bit version, but the question is which OS wheezy or stretch. Opinions are welcome.
  • Moderator
  • Moderator
20 May 2020 22:55 #168414 by tommylight
Replied by tommylight on topic Which CNC system to install?
You can try stretch as it is ready to use even from usb, at least you will know if the card works, but on the other side, does that PC have a built in parallel port ? Pretty sure almost all of the PC's from that era should have one.
There are also the options of installing everything, Linux, Kernel and Linuxcnc, should be easy enough if you follow these tutorials:
For Linux Mint:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
And Debian Buster:
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
Most probably the download will last longer than installing everything! :)
  • TglEMC
  • Senior Member
  • Senior Member
22 May 2020 20:21 #168602 by TglEMC
Replied by TglEMC on topic Which CNC system to install?
Thank you for your reply.
I don't know what era your thinking this machine is from but is not that old and there is no built in parallel port.
Unfortunately none of the options you presented work on fresh Debian Stretch install. I did try 2 of the Debian nonfree ISOs, debian-live-10.4.0-amd64-gnome+nonfree.iso and debian-live-10.4.0-amd64-kde+nonfree.iso. Neither of them will install due to the old no apic problem.
Unless you have any other success suggestions I'm back where I started trying to get parallel drivers installed.
Thank you for your help.
22 May 2020 20:43 - 22 May 2020 20:44 #168605 by rodw
Replied by rodw on topic Which CNC system to install?
Its always best to use the standard distributions. from the main site go to downloads.
I would suggest the Stretch build and select this ISO for 64 bit.
linuxcnc-stretch-uspace-amd64.iso
This will use the preempt_rt kernel which may have an impact on latency over RTAI but Wheezy may be too old to support all your hardware.
If you have to use RTAI, I would look at a Linux Mint version. I fouind Mint had much better hardware driver support out of the box. But that was before the Stretch ISO existed.
Last edit: 22 May 2020 20:44 by rodw.
  • TglEMC
  • Senior Member
  • Senior Member
22 May 2020 21:56 #168607 by TglEMC
Thank you! I will try that ISO.
The the build I installed was linuxcnc-stretch-uspace-amd64-r13.iso. I don't think I have to use real-time, this machine should be fast enough without it.
There are so many ISO's, is very difficult to know which one to use.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
22 May 2020 23:41 #168613 by BeagleBrainz
Replied by BeagleBrainz on topic Which CNC system to install?
You have to use real-time, no ifs or buts. It doesn’t matter how fast the machine is.
There is a Mint ISO that has linuxcnc installed that you can boot from USB and run the latency test to see how it will work.
  • TglEMC
  • Senior Member
  • Senior Member
23 May 2020 18:41 #168707 by TglEMC
That is true doesn't every linuxCNC install use real-time?
  • TglEMC
  • Senior Member
  • Senior Member
23 May 2020 20:31 #168718 by TglEMC
Okay so I tried mint 64 bit. It will not install due to the APIC problem in the options tab with noapic does not work.
all of the debian stretch builds have the same kernel problems trying to install parallel port drivers as all other I have tried.
All I need to do is get the parallel port drivers installed on any system, I don't care which.
Is there an appropriate Forum for this?
23 May 2020 21:10 #168721 by PCW
Replied by PCW on topic Which CNC system to install?
Normally you do not need to install parallel port drivers
  • TglEMC
  • Senior Member
  • Senior Member
23 May 2020 21:24 #168722 by TglEMC
Every PCI card ever made as to have a driver installed.
Time to create page: 0.170 seconds
