Which CNC system to install?
- Thank you received: 5334
23 May 2020 22:03 #168727
Replied by PCW on topic Which CNC system to install?
Maybe on Windows, Linux has built in drivers for most parallel port chips
- Thank you received: 7490
23 May 2020 22:09 #168728
Replied by tommylight on topic Which CNC system to install?
Hmmmmm...... it seems you have one of those "software" parallel ports, they do not work with Linuxcnc or Linux at all.
I do have plenty of PCI parallel port cards with NetMos chips, i never ever installed any driver for them in Linux.
If you type
sudo lspci -v
in a terminal, does it show anything resembling a parallel port, the "driver in use" should say "parport".
If you type
sudo lspci -v
- TglEMC
- Thank you received: 4
23 May 2020 22:25 #168729
by TglEMC
Replied by TglEMC on topic Which CNC system to install?
Yes it does.
Parallel controller: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Flags: bus master, medium devsel, latency 0, IRQ 16, NUMA node 0
I/O ports at 9c00
I/O ports at 9800
Memory at fdbff000 (32-bit, non-prefetchable) [size=4K]
Memory at fdbfe000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [48] Power Management version 2
Kernel driver in use: parport_pc
Kernel modules: parport_pc
But LinuxCNC says that the parallel port is not found.
I/O ports at 9c00
I/O ports at 9800
23 May 2020 22:40 - 23 May 2020 22:41 #168734
What address (or port number) are you using in your hal file?
( If this is the only parallel port in your system, '0' should work )
Last edit: 23 May 2020 22:41 by PCW.
- TglEMC
23 May 2020 22:47 #168735
by TglEMC
I don't know the Debian OS well enough to know what that is. Where you do I find the hal file?
23 May 2020 22:57 #168737
The "hal" file (or files) and "ini" file are the files that are used to
customize LinuxCNC for a particular machine and interface hardware
Most often, for a parallel port, the hal/ini files are created by the stepconf utility
These files are normally located in ~/linuxcnc/configs
- TglEMC
23 May 2020 23:14 #168740
by TglEMC
stepconf shows the Parport base address set to 0. CNC shows Linux parallel port @888 not found.
23 May 2020 23:33 #168746
You may have to enter one of the port addresses found by lspci
( 0x9C00 or 0x9800 ) for LinuxCNC to find the hardware
- TglEMC
24 May 2020 00:01 #168749
by TglEMC
Thank you for your help.
Setting the address to 9c00 appears to have fixed the parallel port not found issue. Looks like I now need to read up on the configuration. The manual controls are grayed out.
