Debian Wheezy 2.7 to 2.9?
- Catch22
- Thank you received: 17
14 Jun 2020 23:59 #171659
by Catch22
Debian Wheezy 2.7 to 2.9? was created by Catch22
Is it possible to go from Debian Wheezy 2.7.14 to 2.9 or do I have to use a different Debian version.
- Thank you received: 7490
15 Jun 2020 00:15 #171660
Replied by tommylight on topic Debian Wheezy 2.7 to 2.9?
buildbot.linuxcnc.org/~buildmaster/dists/wheezy/master-rt/
Not sure if it was 32 or 64 bit, so check and chose from there, usually the latest build is at or near the bottom of the page.
Download, doubleclick, install, that should be it.
If there is no gdebi installed, that might be a problem as the repositories for Wheezy are no longer working, so search how to install a deb package.
The following user(s) said Thank You: Catch22
- bbsr_5a
- Thank you received: 106
15 Jun 2020 07:00 #171687
by bbsr_5a
Replied by bbsr_5a on topic Debian Wheezy 2.7 to 2.9?
hi
the main info on updating is here
consider using uspace for the QTvcp Dragon guis
gnipsel.com/linuxcnc/index.html
- phillc54
- Thank you received: 2100
15 Jun 2020 10:47 #171735
by phillc54
linuxcnc.org/docs/devel/html/gui/qtvcp.html
linuxcnc.org/docs/devel/html/gui/qtdragon.html
Replied by phillc54 on topic Debian Wheezy 2.7 to 2.9?
Qtvcp and Dragon are on the LinuxCNC website.hi
- Catch22
15 Jun 2020 14:28 #171746
by Catch22
Replied by Catch22 on topic Debian Wheezy 2.7 to 2.9?
Hey guys I'm pretty new to Linux, I've been fumbling my way through it so far but can you please tell me what this is for.
Thanks Mike
Thanks Mike
- phillc54
15 Jun 2020 23:02 #171783
by phillc54
TBH I don't know what his intention was, I was just pointing out that the link wasn't to what he suggested.
- Catch22
17 Jun 2020 22:40 #171933
by Catch22
Ok so I just checked and Debian Wheezy 2.7 is only 32 bit, does that mean I need to use a different Debian package that is 64 bit to upgrade to version 2.9.
- phillc54
17 Jun 2020 23:33 #171936
by phillc54
Buildbot builds both 64bit and 32bit master branch (2.9) for Wheezy so just follow the Buildbot instructions, you would still use:
deb http://buildbot.linuxcnc.org/ wheezy master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ wheezy master-rtpreemptbuildbot.linuxcnc.org/
Time to create page: 0.435 seconds
