Install stops "Failed to Partition Hard Disk
- kramerda
- Thank you received: 14
26 Jun 2020 18:51 #172811
by kramerda
Install stops "Failed to Partition Hard Disk was created by kramerda
Error message: " Failed to partition the selected disk
This probably happened because the selectd disk or free space is too small"
New machine - runs 'LIVE', Linuxcnc stretch-uspace-amd64-r13.iso, fine from USB flash drive
When doing a Graphical install from that USB , install hangs up when tries to write to virgin, clean, 512 GB SSD drive --
-- only other drive in the machine.
Bios (msi) sees the SSD drive.
Bios (msi) defaults to CSM (not UEFI) and AHCI (not RAID)
Not sure what to try next ????f
Thanks for any feedback
Dennis
Dennis
- Thank you received: 7490
26 Jun 2020 19:07 #172812
Replied by tommylight on topic Install stops "Failed to Partition Hard Disk
Disable secure boot in BIOS.
Time to create page: 0.139 seconds
