WLAN during DEBIAN 9.12 installation works, but not after
- Tarja
12 Jul 2020 09:13 #174368
by Tarja
WLAN during DEBIAN 9.12 installation works, but not after was created by Tarja
Hi, maybe someone has an idea.
I have nano WLAN Stick which works fine during installation of Debian 9.12 64bit netinst but once finished and restarted, I am not able to reconnect to same WLAN. It doesn't work.
Already tried to delete it and recreated an new connections but no success.
Any idea why it would work during installation but not after?
and is there somewhere a log to see whats happening during the connection process?
Thx
Thx
- Thank you received: 7490
12 Jul 2020 10:05 #174374
Replied by tommylight on topic WLAN during DEBIAN 9.12 installation works, but not after
Use the "non free" version of Debian NetInstall.
- Tarja
12 Jul 2020 10:25 - 12 Jul 2020 10:27 #174375
by Tarja
Replied by Tarja on topic WLAN during DEBIAN 9.12 installation works, but not after
Last edit: 12 Jul 2020 10:27 by Tarja.
12 Jul 2020 11:51 #174379
OK, in that case i have no clue why it does not work.
I thought you were using that since it works during install, so is there any thing like "install proprietary drivers and codex" in the menus during install ?
- Mike_Eitel
- Thank you received: 183
12 Jul 2020 12:20 #174380
by Mike_Eitel
Replied by Mike_Eitel on topic WLAN during DEBIAN 9.12 installation works, but not after
What shows your ip configuration
- Tarja
12 Jul 2020 13:38 #174384
by Tarja
What do you mean? (automatic dhcp)
An other info:
I installed accidently the 32bit version of the same linux version and there the WLAN worked also after installation.
Could it be a driver problem. Different driver for installation and after for running?
An other info:
- Thank you received: 4152
13 Jul 2020 08:20 #174481
Replied by rodw on topic WLAN during DEBIAN 9.12 installation works, but not after
The nano is a but funny based on my experience. When I first tried to use Wheezy, I was able to compile the driver. Then I changed PC's (pre stretch), it never worked and then when I adopted Linux Mint 17.3 , it was supported out of the box with no issues. I also found a better quality WLAN Access point improved network reliability but I doubt that is nano related..
Time to create page: 0.248 seconds
