- LinuxCNC
- Installing LinuxCNC
- http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file
- ikkuh
- Thank you received: 48
22 Jul 2020 13:46 - 23 Jul 2020 11:27 #175396
by ikkuh
http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file was created by ikkuh
Err:11 buildbot.linuxcnc.org stretch Release
403 Forbidden
Reading package lists... Done
E: The repository 'buildbot.linuxcnc.org stretch Release' does no longer have a Release file.
ikkuh@LinuxCNC-MESA:~$ cat /etc/debian_version
/etc/apt/sources.list.d/linuxcnc.list
403 Forbidden
9.13/etc/apt/sources.list.d/linuxcnc.list
deb http://buildbot.linuxcnc.org/ stretch master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ stretch master-rtpreemp
Last edit: 23 Jul 2020 11:27 by ikkuh.
- Thank you received: 7490
22 Jul 2020 15:07 #175400
Replied by tommylight on topic http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file
Something has gone south, here is what i get:
E: Failed to fetch http://buildbot.linuxcnc.org/dists/stretch/InRelease 403 Forbidden [IP: 71.218.153.245 80]
E: The repository 'http://buildbot.linuxcnc.org stretch InRelease' is no longer signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
The following user(s) said Thank You: ikkuh
- ikkuh
23 Jul 2020 11:27 - 23 Jul 2020 11:30 #175513
by ikkuh
Replied by ikkuh on topic http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file
Problem still persists here. No info on buildbot.linuxcnc.org either.
There were some problems in the past (disk full if I recall correctly).
There are some differences between the two error messages though.
Mine speaks of :
Yours is more specific:
Mine speaks of :
E: The repository 'http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file.E: The repository 'http://buildbot.linuxcnc.org stretch InRelease' is no longer signed.
Last edit: 23 Jul 2020 11:30 by ikkuh.
23 Jul 2020 12:24 #175534
Yup, still not working.
Had the same issues when i was doing the "quick and easy" installs for Linux Mint and Debian, whenever i would forget to add ' to the apt-add line, so that makes me thing something has changed on the server or in the naming of things there.
- ki4swy
23 Jul 2020 18:15 - 23 Jul 2020 20:29 #175560
by ki4swy
Replied by ki4swy on topic http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file
buildbot is down ( 503 Unavailable )... and git is giving me "fatal: the remote end hung up unexpectedly" ..
Trying to upgrade to 2.8 to support joints ... UGG..
Last edit: 23 Jul 2020 20:29 by ki4swy.
23 Jul 2020 18:31 #175562
Error 503 on both buildbots.
That is a server side issue.
- ikkuh
23 Jul 2020 19:51 #175568
by ikkuh
@andypugh Do you have any idea?
- denhen89
- Thank you received: 27
24 Jul 2020 15:11 #175643
by denhen89
Replied by denhen89 on topic http://buildbot.linuxcnc.org stretch Release' does no longer have a Release file
I deleted libmodbus, because i trying to get my VF-S11 Toshiba VFD to work over modbus. Unfortunately that deleted also somehow Linuxcnc.
Now i cannot install 2.9 because the builbot server is down. That suc...
Is there no other server available
24 Jul 2020 15:23 #175645
Now it's 403, permission denied !
- denhen89
24 Jul 2020 15:59 #175650
by denhen89
i can access the site, looks normal, but i cannot update linuxcnc from 2.7 to 2.9.
..does not have a release file...
- LinuxCNC
Time to create page: 0.107 seconds
