Master issues with menu entries being setup in accessories menu
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
06 Aug 2020 21:27 #177550 by tommylight
Noticed last 2 to 3 weeks of updates will not set up LinuxCNC on the CNC menu entry as it normally did but will throw that on the accessories menu.
This is with latest Master builds and Linux Mint 19.3 and Mint 20.
07 Aug 2020 12:18 #177604 by andypugh
I wonder if it works with Debian?
Are you able to try 2.8 and see if that has the same problem on Mint? I did recently make some changes.
github.com/LinuxCNC/linuxcnc/commit/c692...5cdb8b4d4e53cd10c8a9
  • Moderator
  • Moderator
07 Aug 2020 12:55 #177614 by tommylight
Yes of course, will report back.
07 Aug 2020 13:06 - 07 Aug 2020 13:06 #177615 by bevins
I just installed Debian 10 two days ago and it didn't put it in menu where it normally does.
I thought that's weird and started Linuxcnc from terminal
Last edit: 07 Aug 2020 13:06 by bevins.
  • Moderator
  • Moderator
07 Aug 2020 13:08 #177616 by tommylight
Tested the 2.8 version of LinuxCNC and it puts the menu entries in the "other" section of the menu.
Master puts them in "accessories" .
Time to create page: 0.087 seconds
