LinuxCNC with Probe Basic
- CNCer
22 Aug 2020 18:50 #179023
by CNCer
LinuxCNC with Probe Basic was created by CNCer
I used to program CNC G&M codes back in the late 1980s in printed circuit board manufacturing - large scale. Seems like soooo long ago. Anyway, I'm just beginning to dabble in machining metal and am researching my first manual mill purchase. Having said that, at some point I would like to turn this manual mill into a CNC mill. Luckily I happened across this forum.
I've been a Linux user for years with my favorite distro being Debian Cinnamon edition. I'm currently running Debian 10 Buster. I would like to install LinuxCNC with Probe Basic to play with while saving for my mill. I've read a few posts but not sure where to start. Any suggestions would be most helpful. Thank you.
- anfänger
- Thank you received: 267
22 Aug 2020 20:09 #179025
by anfänger
Replied by anfänger on topic LinuxCNC with Probe Basic
Actually this is not that difficult
kcjengr.github.io/probe_basic/dev_install.html
Is used this twice to install probe basic.
Some packages are missing when compiling, but if you know your way around Linux it’s easy to load them and recompile
Have fun with it
Patrick
Have fun with it
Patrick
- chris@cnc
- Thank you received: 140
22 Aug 2020 20:44 - 22 Aug 2020 20:46 #179031
by chris@cnc
Replied by chris@cnc on topic LinuxCNC with Probe Basic
it is very good to know what the end is. I can't give you a manual, but I can give you an example of how I started. I no longer wanted to push my router bits over the wood by hand. I still have Debian 9 and my sources.list
echo deb buildbot.linuxcnc.org/ stretch 2.8-rtpreempt >>/etc/apt/sources.list added and read the installation instructions here.
Debian 10 is written here.
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
I didn't want a simulator and ordered the 7i76E + 1 servo and started turning it with an NC program. When it worked, the joy was great and I would like to thank everyone who helped me on this path and the Linuxcnc developers who made this possible.
When the first motor turns, the rest comes by itself. Just do it. It is not easy until then, but the costs are manageable and then you will see what is possible and what it will cost. Last advice good electrics reduce many problems and use a large control cabinet. So things can still added. The ideas come from making.
The manuals are here linuxcnc.org/documents/
Last edit: 22 Aug 2020 20:46 by chris@cnc.
- Thank you received: 7490
22 Aug 2020 20:44 #179032
Replied by tommylight on topic LinuxCNC with Probe Basic
If you need to install LinuxCNC, have a look here:I'm currently running Debian 10 Buster. I would like to install LinuxCNC with Probe Basic to play with while saving for my mill.
- CNCer
22 Aug 2020 22:41 - 22 Aug 2020 22:50 #179042
by CNCer
Replied by CNCer on topic LinuxCNC with Probe Basic
tommylight...I was using your Method 2 and received the following:
gpg: keyserver receive failed: Connection timed out
***NOTE*** My firewall was blocking so I used port 80 and it worked fine:
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
Last edit: 22 Aug 2020 22:50 by CNCer.
23 Aug 2020 06:08 #179064
Fixed that on the original topic, thank you.
- CNCer
23 Aug 2020 16:26 #179114
by CNCer
tommylight...So I've backtracked and installed Debian 9 Stretch. Are there any install instructions such as your method #2 for Debian 10? I've been poking around and can't seem to find a straight forward method of installing from the terminal like you listed for Debian 10. Any ideas? Thank you.
23 Aug 2020 17:54 #179125
Do you mean QtPyVCP?
- chris@cnc
23 Aug 2020 18:32 - 23 Aug 2020 18:33 #179129
by chris@cnc
that's all
sudo apt-add-repository 'http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt'
sudo apt-get update
sudo apt-get -y install linuxcnc-uspace
Last edit: 23 Aug 2020 18:33 by chris@cnc.
- CNCer
23 Aug 2020 19:20 - 23 Aug 2020 19:42 #179132
by CNCer
tommylight...I apologize. I meant I have a clean install of Debian 9 Stretch on my computer. I wanted to do a fresh install of LinuxCNC by the terminal such as what you showed in your Debian 10, Method 2 install.
chris@cnc...Is this a clean install of LinuxCNC by chance? Is that all I have to copy and paste into my terminal? It seems there should be more. I thought there might be something to do with using a particular kernel. I'm not sure though.
I noticed when I installed Probe Basic, the instructions (kcjengr.github.io/probe_basic/quick_start.html) state in step 4, "After installation probe basic should show up in the linuxcnc launch screen and you can select to create a desktop icon for it by selecting the check box to do so at the bottom of the page." I didn't see Probe Basic in the LinuxCNC launch screen. Any ideas why?
Last edit: 23 Aug 2020 19:42 by CNCer.
Time to create page: 0.568 seconds
