Updating Run-in-place
- AgentWD40
- Thank you received: 96
23 Aug 2020 14:15 - 23 Aug 2020 14:40 #179101
by AgentWD40
Updating Run-in-place was created by AgentWD40
My machine has linuxcnc 2.9.0-pre0 that I installed back in januaryish that I compiled from these instructions: linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
Can anyone give me the commands needed to update this installation?
(my internet connection here is limited to wifi hotspot)
[EDIT]
So I cd'ed into the ~/linuxcnc-dev/ directory and ran
> git pull
> cd ./src
> ./autogen.sh
> ./configure --with-realtime=uspace
> make
> sudo make setuid
Seems to have run fine. Is that correct? The linuxcnc splash screen still says v2.9.0-pre0 though
[EDIT]
> git pull
> cd ./src
> ./autogen.sh
> make
> sudo make setuid
Last edit: 23 Aug 2020 14:40 by AgentWD40.
- AgentWD40
24 Aug 2020 00:35 #179165
by AgentWD40
Replied by AgentWD40 on topic Updating Run-in-place
Can anyone tell me if the above is all that's required, `git pull` ?
Since the terminal still reports the same 2.9.0-pre0 I don't know how to tell if I'm actually running the latest updates.
- BeagleBrainz
- Visitor
24 Aug 2020 02:33 #179181
by BeagleBrainz
Replied by BeagleBrainz on topic Updating Run-in-place
Yes
There is a couple of things you can do.
1: Checkout the output after you do "git pull"
2: Read the changelog in the debian folder
- Thank you received: 4151
24 Aug 2020 10:38 #179215
Replied by rodw on topic Updating Run-in-place
Try this
Then in Git, click on the code tab and you should see the latest commit numbers and compare
github.com/LinuxCNC/linuxcnc
The last one also shows on the main gits screen
$ git log --oneline -1Then in Git, click on the code tab and you should see the latest commit numbers and compare
The following user(s) said Thank You: AgentWD40
- phillc54
- Thank you received: 2100
25 Aug 2020 05:10 #179313
by phillc54
Replied by phillc54 on topic Updating Run-in-place
git log -1 will show the commit date, that would give you a pretty good ideaTry this
Time to create page: 0.070 seconds
