Raspberry Pi Buildbot .iso
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
28 Aug 2020 18:03 - 28 Aug 2020 19:46 #179860 by Roguish
Raspberry Pi Buildbot .iso was created by Roguish
Well, downloaded the build, used the rpi imager_1.4 and created a bootable sd.
and it works!!! boots up clean and pretty.
Now, I'd like to play with it, but sudo wants a password..........
The username is 'linuxcnc'
Little help here, please.
What's the associated password?
tried 'root' and 'raspberry', no success........
ok, apparently the 'linuxcnc' user password is 'tux'
still no idea what the 'root' password is............
ok, more effort.
did a sudo su into superuser, the used the regular password change to set 'root' password to 'tux', same as user 'linuxcnc'
seem so be ok.
Last edit: 28 Aug 2020 19:46 by Roguish.
22 Sep 2020 11:37 - 22 Sep 2020 11:37 #183279 by andypugh
Replied by andypugh on topic Raspberry Pi Buildbot .iso
On the current released iso the username and password have been changed to the conventional pi / raspberry
Last edit: 22 Sep 2020 11:37 by andypugh.
The following user(s) said Thank You: Roguish, phillc54, AgentWD40
Time to create page: 0.090 seconds
