recompile xemc.cc from command line
11 Sep 2020 07:35 #181729 by anpoit00
recompile xemc.cc from command line was created by anpoit00
Hello,
I would like to recompile xemc.cc from command line.
Obviously I can’t use halcompile. I tried to find a command in make file but I was not able to find something.
Great thanks
02 Oct 2020 11:04 #184554 by andypugh
Replied by andypugh on topic recompile xemc.cc from command line
I have not found a way to compile a single file in LinuxCNC (which is not to say that there isn't a way that I haven't found)
It's probably easiest to recompile a run-in-place version of LinuxCNC, test with that, and then move the object file over when it is working.
Time to create page: 0.070 seconds
