usb ports and wifi not working after linuxcnc installation on a laptop partition
  • sibelius
  • sibelius's Avatar Topic Author
  • Visitor
  • Visitor
28 Sep 2020 12:00 #184146 by sibelius
Hi everyone,
I tried to install linuxcnc 2.8 on my laptop.
The installation went well but, at the beginning when the double boot goes (as a first choice on linuxcnc), all my usb ports and the wifi does not work any more.
All the usb ports seems dead.
I tried different solutions, like modify the grub boot loader, trying to enable IOMMU but nothing seems to work.
If I reboot and go on windows10, everything goes back to normal.
Any help would be appreciated
Thanks.
V.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
28 Sep 2020 12:07 - 28 Sep 2020 12:12 #184149 by BeagleBrainz
Unless you give a bit more concise information regarding your hardware it's like wondering around in the dark with your eyes closed and a welding helmet on.
What model is your laptop ?
What ISO did you use to install ie: version ?
Do you know what exact model of a wifi adapter you are using, how is it connected ?
If you run
lspci
in a terminal in debian what is the output ?
There is a chance that the version of linux you installed does not support your hardware, very rare nowadays but can happen. Sometimes Debian doesn't include "non-free" firmware blobs that some wifi adapters need.
Last edit: 28 Sep 2020 12:12 by BeagleBrainz.
  • sibelius
  • Visitor
  • Visitor
28 Sep 2020 13:24 #184169 by sibelius
Hi thanks for you answer.
My laptop is a lenovo E430.
The iso image I used is : linuxcnc-2.7.14-wheezy.iso
I ve burned on a CD and then I upgrade to version 2.8.
I hope you can see the output from the photo.
Thanks for your help.
V.
  • BeagleBrainz
  • Visitor
  • Visitor
28 Sep 2020 19:09 #184201 by BeagleBrainz
Try the Buster ISO.
Some tests have been done with that laptop and it doesn’t appear to be a good candidate for Linuxcnc. Tho your mileage may vary.
There also is a Linux Mint 19.3 iso available. Links can be found under “Installing Linuxcnc” section of the forum.
28 Sep 2020 20:33 #184207 by rodw
I would say Wheezy is far to old to have support for your laptop hardware. The 2.7 ISO you used is no longer the release version of Linuxcnc. Download the current 2.8 release ISO on Buster and try that. I suspect it will solve your problem. If not try Mint. It works on most laptops.
The following user(s) said Thank You: sibelius
28 Sep 2020 20:50 #184211 by tommylight
  • sibelius
  • Visitor
  • Visitor
29 Sep 2020 02:46 #184236 by sibelius
Thank you very much again for your help.
I will try buster iso and if it does not lead to any result I will have a go with the other option.
Regards,
V.
  • sibelius
  • Visitor
  • Visitor
01 Oct 2020 09:43 #184472 by sibelius
Hi every one,
I finally manage to install linuxCNC on my laptop.
So basically what i did was to install first linux Mint 19.3 as suggested.
Installation was no problem but I have to deal with a few issues.
One was the fact that i need to install the firmware for my wireless chip; I solve that with a b43 firmware.
The other issue was that Firefox was not able to resolve host name; I tried first to ping 8.8.8.8 and www.google.com with no luck.
What I did in the end was to apt-get update and dis install and reinstall Firefox.
Reboot and wireless with a working Firefox was ready to go.
Next step was to install linuxCNC with the procedure suggested.
I did not have time yet to test linuxCNC but, at the first look seems ok or at least it open.
So far everything seems in order.
I have other question that will come from my effort in approaching this software but, at the present moment I have one which I soon will open in a new topic.
I consider this topic close for my point of view.
Thank you very much again for all the help I have received.
Regards,
V.
  • BeagleBrainz
  • Visitor
  • Visitor
01 Oct 2020 09:49 #184473 by BeagleBrainz
Any reason you didn't use the Mint ISO with Linuxcnc pre installed ? Just out of interest.
Your browser has no affect on DNS. It was more likely rebooting and, I'm assuming this, getting your IP, DNS & Gateway via dhcp once rebooted.
  • sibelius
  • Visitor
  • Visitor
01 Oct 2020 10:42 #184479 by sibelius
I did not it existence.
I just followed without thinking to much the instructions.
Tried before the buster iso with no much luck and then I went straight to linux Mint
I follow the guide on a topic in installing linuxCNC.
I find that researching is very tiring so if someone comes with a way to try some solution, I go for that.
So, try answering your question, is basically due to my lazy mind.
Actually if you have handy the link to that iso and if it does not take to much of you time, would be nice to posted so I can burn on a dvd just in case for future installation.
Thanks.
V.
Time to create page: 0.162 seconds
