Live view not available in axis + error message, linuxcnc 2.8.0 debian
07 Oct 2020 07:32 - 07 Oct 2020 07:34 #185211 by SvenH
I have just installed the new Buster Live iso and almost have my old config working.
When I start I get an error message, even before the splash screen is gone:
"Near line 0 of /usr/share/axis/images/axis.ngc:
exception during generator call: TypeError: 'NoneType' object is non callable"
This happens with every file I open.
When searching the error the few answers I find seem to relate to python.
I checked if I had python 2.7 installed, I had, as well as 3.4?
(The python errors I read about say "not callable" instead of "non calable")
I removed python 3.4, that dis not change anything.
Any thoughts?
Last edit: 07 Oct 2020 07:34 by SvenH.
  • Moderator
  • Moderator
10 Oct 2020 21:47 #185644 by tommylight
Did you try starting one of the included sim configs ?
And just in case, did you check the md5sum of the downloaded ISO ?
11 Oct 2020 10:35 #185694 by SvenH
I have tried to start one of the included configs, no success yet.
I tried to find the md5sum for the iso I have but it is not on the download page, any idea where to look?
13 Oct 2020 11:23 #185966 by SvenH
I have downloaded the buster iso again and the md5sum does differ from that of the one I installed.
After some hard searching I found the md5sum of the current iso, it is here:
linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html
section "getting started" 1.3
I'll try reinstalling...
Thanks so far!
13 Oct 2020 12:13 #185974 by SvenH
Unfortunately, no Difference....
Time to create page: 0.153 seconds
