Clone system
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Oct 2020 16:20 #185619 by Mike_Eitel
Clone system was created by Mike_Eitel
If you never cloned before with clonezilla, this is in my opinion an easy intro:
Mike
The following user(s) said Thank You: tommylight, Aciera
  • Moderator
  • Moderator
10 Oct 2020 21:37 #185640 by tommylight
Replied by tommylight on topic Clone system
He does tend to wind a lot, but he is pretty good.
31 Oct 2020 23:48 #187957 by lrak
Replied by lrak on topic Clone system
clonezilla works if you are just doing one drive - but if you are doing any volume of drives - look a bit further. I set up a duplication system - had it run via scripts.. and the package partclone was faster.
The trick was to clone the partition table - then run partclone - which understands how to copy only what is needed without looking at the files one by one. The speed limit was mostly the drive I/O - complex software with windows system and a second partition with Debian took only 5-min+.
I have the old scrip if you are interested - everything changes so there is likely something would need to be tweaked.
Time to create page: 1.375 seconds
