Switching to a new computer to run Linuxcnc 2.8 problems?
- Catch22
- Thank you received: 17
17 Oct 2020 16:18 - 17 Oct 2020 17:16 #186371
by Catch22
Switching to a new computer to run Linuxcnc 2.8 problems? was created by Catch22
Note: Using POSIX realtime
hm2_pci: rtapi_app_main: No such device (-19)
./Delta_Mill.hal:9: waitpid failed /usr/bin/rtapi_app hm2_pci
./Delta_Mill.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Delta_Mill.hal:9: insmod for hm2_pci failed, returned -1
4745
Stopping realtime threads
Unloading hal components
This is the errors im getting, can anyone point me in the right direction please.
Thanks Mike
Please let me know if I put this in the wrong section.
4745
Thanks Mike
Last edit: 17 Oct 2020 17:16 by Catch22. Reason: Change
- Thank you received: 7488
17 Oct 2020 18:16 #186375
Replied by tommylight on topic Switching to a new computer to run Linuxcnc 2.8 problems?
Is there a Mesa card somewhere ?
- Catch22
17 Oct 2020 18:56 #186376
by Catch22
Replied by Catch22 on topic Switching to a new computer to run Linuxcnc 2.8 problems?
Yes there is the 5i25 and 7i77.
17 Oct 2020 21:02 #186383
What does
sudo lspci -v
in a terminal say ?
sudo lspci -v
in a terminal say ?
- Catch22
17 Oct 2020 22:12 #186396
by Catch22
mike@mike-OptiPlex-780:~$ sudo lspci -v
[sudo] password for mike:
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
Subsystem: Dell 4 Series Chipset DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: f7900000-f79fffff
Capabilities: [88] Subsystem: Dell 4 Series Chipset PCI Express Root Port
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03) (prog-if 00 [VGA controller])
Subsystem: Dell 4 Series Chipset Integrated Graphics Controller
Memory at f7c00000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at ecb0
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [d0] Power Management version 2
Kernel driver in use: i915
Kernel modules: i915
00:02.1 Display controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
Memory at f7b00000 (64-bit, non-prefetchable) [size=1M]
00:03.0 Communication controller: Intel Corporation 4 Series Chipset HECI Controller (rev 03)
Subsystem: Dell 4 Series Chipset HECI Controller
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at feda6000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: mei_me
Kernel modules: mei_me
00:03.2 IDE interface: Intel Corporation 4 Series Chipset PT IDER Controller (rev 03) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Dell 4 Series Chipset PT IDER Controller
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 18
I/O ports at fe80
I/O ports at fe90
I/O ports at fea0
I/O ports at feb0
I/O ports at fef0
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: ata_generic
Kernel modules: pata_acpi
00:03.3 Serial controller: Intel Corporation 4 Series Chipset Serial KT Controller (rev 03) (prog-if 02 [16550])
Subsystem: Dell 4 Series Chipset Serial KT Controller
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 17
I/O ports at ecb8
Memory at f7ad8000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: serial
00:19.0 Ethernet controller: Intel Corporation 82567LM-3 Gigabit Network Connection (rev 02)
Subsystem: Dell 82567LM-3 Gigabit Network Connection
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f7ae0000 (32-bit, non-prefetchable) [size=128K]
Memory at f7ad9000 (32-bit, non-prefetchable) [size=4K]
I/O ports at ece0
Capabilities: [c8] Power Management version 2
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [e0] PCI Advanced Features
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Subsystem: Dell 82801JD/DO (ICH10 Family) USB UHCI Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at ff20
Capabilities: [50] PCI Advanced Features
Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #5 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at ff00
00:1a.2 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #6 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 22
I/O ports at fc00
00:1a.7 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB2 EHCI Controller #2 (rev 02) (prog-if 20 [EHCI])
Subsystem: Dell 82801JD/DO (ICH10 Family) USB2 EHCI Controller
Memory at f7ada000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 82801JD/DO (ICH10 Family) HD Audio Controller (rev 02)
Subsystem: Dell 82801JD/DO (ICH10 Family) HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f7adc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801JD/DO (ICH10 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: f7800000-f78fffff
Prefetchable memory behind bridge: 00000000fc000000-00000000fc1fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Dell 82801JD/DO (ICH10 Family) PCI Express Port 1
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link
00:1c.1 PCI bridge: Intel Corporation 82801JD/DO (ICH10 Family) PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 17
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f7700000-f77fffff
Prefetchable memory behind bridge: 00000000fc200000-00000000fc3fffff
Capabilities: [90] Subsystem: Dell 82801JD/DO (ICH10 Family) PCI Express Port 2
00:1d.0 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at ff80
00:1d.1 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
I/O ports at ff60
00:1d.2 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at ff40
00:1d.7 USB controller: Intel Corporation 82801JD/DO (ICH10 Family) USB2 EHCI Controller #1 (rev 02) (prog-if 20 [EHCI])
Memory at ff980000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
Capabilities: [50] Subsystem: Dell 82801 PCI Bridge
00:1f.0 ISA bridge: Intel Corporation 82801JDO (ICH10DO) LPC Interface Controller (rev 02)
Subsystem: Dell 82801JDO (ICH10DO) LPC Interface Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JD/DO (ICH10 Family) SATA AHCI Controller (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: Dell 82801JD/DO (ICH10 Family) SATA AHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 30
I/O ports at fe00
I/O ports at fe10
I/O ports at fe20
I/O ports at fe30
I/O ports at fec0
Memory at ff970000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 82801JD/DO (ICH10 Family) SMBus Controller (rev 02)
Subsystem: Dell 82801JD/DO (ICH10 Family) SMBus Controller
Flags: medium devsel, IRQ 9
Memory at f7adb000 (64-bit, non-prefetchable)
I/O ports at 0980
Kernel modules: i2c_i801
I/O ports at ecb0
I/O ports at fe80
I/O ports at fe90
I/O ports at fea0
I/O ports at feb0
I/O ports at fef0
I/O ports at ecb8
I/O ports at ece0
I/O ports at ff20
I/O ports at ff00
I/O ports at fc00
I/O ports at ff80
I/O ports at ff60
I/O ports at ff40
I/O ports at fe00
I/O ports at fe10
I/O ports at fe20
I/O ports at fe30
I/O ports at fec0
I/O ports at 0980
- Catch22
17 Oct 2020 22:15 #186398
by Catch22
i have no idea what any of this means, but i dont see anything about the mesa cards.
17 Oct 2020 22:22 #186401
Switch off the PC, remove the power cord, wait 5 minutes,
-remove the mesa card
-with a soft cotton cloth clean the terminals on the bottom of the card (do not use synthetic cloth, that will kill the card)
-reseat the card back into it's slot by gently pushing it down and moving it slightly back and forth
-make sure the card is fully seated
-power on the PC
-check the LED's on the card from the moment you press the power button and report here.
In case it does not work, try another slot if possible.
-power on the PC
- Catch22
17 Oct 2020 23:03 - 17 Oct 2020 23:25 #186407
by Catch22
cleaned and reseated, when i hit the power button the cr3 and cr4 light up red for less than a second then they go out and no other lights are on. This is on the 5i25 card. I just switched the card back to the old computer and the mill works fine, I checked the lights on the 7i77 card and switched it back to the new computer and the same lights are on the board. So it must be something else. i have read before the if I dont have the right kernal it could be a problem,and im not sure which one its running on right now. Could that be it.
Last edit: 17 Oct 2020 23:25 by Catch22.
- Thank you received: 5330
18 Oct 2020 00:02 #186425
Replied by PCW on topic Switching to a new computer to run Linuxcnc 2.8 problems?
This looks like a a PC hardware or BIOS issue. That is the BIOS did not find the 5I25 card at all (before the OS is even loaded)
The following user(s) said Thank You: Catch22
18 Oct 2020 00:07 #186428
You have the right kernel.Note: Using POSIX realtime
Time to create page: 0.183 seconds
