Switching to a new computer to run Linuxcnc 2.8 problems?
- Catch22
- Thank you received: 17
18 Oct 2020 00:26 #186430
by Catch22
Replied by Catch22 on topic Switching to a new computer to run Linuxcnc 2.8 problems?
Thanks everyone, I think I will try a different computer.
- Catch22
18 Oct 2020 02:42 #186435
by Catch22
OK so I switched computers ran pncconf and Linuxcnc opens but when I hit the power button I get joint 1 on limit switch error and joint 2 on limit switch error. Tried changing the settings in pncconf a few different ways but nothing works, still get the errors.
- Thank you received: 5330
18 Oct 2020 02:54 #186436
Replied by PCW on topic Switching to a new computer to run Linuxcnc 2.8 problems?
If the limit switches work (verify with halshow)
you likely have have the limit switch input polarity
wrong.
wrong.
- Catch22
18 Oct 2020 16:47 #186475
by Catch22
OK so here's what's happening, I switch my 5i25 Mesa card back to my old computer and limits and everything else works fine, I put the 5i25 Mesa card in my new computer with all the pncconf settings exactly the same as the old computer and I keep getting the 1 joint limit errors.
Not really sure where to go from here.
- Thank you received: 7488
18 Oct 2020 17:06 #186477
Replied by tommylight on topic Switching to a new computer to run Linuxcnc 2.8 problems?
Copy the working config to the other PC.
The following user(s) said Thank You: Catch22
- Catch22
04 Nov 2020 15:12 #188313
by Catch22
Ok so I switched to a competely different computer Dell Optiplex 780 and all is working good now.
Thanks everyone for the help.
Thanks Mike
Thanks Mike
