Can't install grub loader error
19 Nov 2020 18:35 #189801 by AdamD
Can't install grub loader error was created by AdamD
I am installing LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO from a dvd. I keep getting error wont install grub loader.
Do I need internet hooked up to install?
  • Moderator
  • Moderator
19 Nov 2020 19:07 #189804 by tommylight
Replied by tommylight on topic Can't install grub loader error
Disable UEFI in BIOS and try again.
I do recall vaguely someone mentioning it needs internet, but seems unlikely as i did install without internet.
19 Nov 2020 19:56 #189813 by AdamD
Replied by AdamD on topic Can't install grub loader error
I have sucure boot disabilabled and I could not find where to turn off uefi.
  • Moderator
  • Moderator
19 Nov 2020 20:22 #189815 by tommylight
If you press F12 or F11 or F9 to chose a boot device, do you get two entries for USB ?
Choose the one with no UEFI.
20 Nov 2020 03:49 #189859 by AdamD
My bios seems real flaky I keep lockup not letting me enter it till I pull the battery to reset it I am going to buy something different.
20 Nov 2020 03:52 #189861 by AdamD
Thank you
18 Jul 2021 18:37 #215245 by Pipik
Replied by Pipik on topic Can't install grub loader error
Hello.
Also getting grub install error.
I cant disable UEFI, got one of that new boards. I have tried several ways, but cant, really.
But I noticed in log screen, saying error because package grub-efi-amd64 cant be found, selftrying other package, also missing, so giving it up with error message.
Any idea?
AMD64 system, installing from USB stick, clean install on entire disk, active EFI partition created (520MB), completely offline (maybe this is the error?)
  • Moderator
  • Moderator
18 Jul 2021 20:05 #215248 by tommylight
Disable "secure boot".
18 Jul 2021 21:33 - 18 Jul 2021 21:36 #215261 by Pipik
There is no problem with "secure boot" (disabled). Another distro installed grub normally. For example, Wheezy have no problem with installing (but have problem with booting because of UEFI, which cant be disabled)
An ideal way for me is somehow install Wheezy with UEFI grub. Wheezy because of RTAI kernel, and EFI grub because damn new board.
Last edit: 18 Jul 2021 21:36 by Pipik.
  • Moderator
  • Moderator
18 Jul 2021 23:16 #215262 by tommylight
You can install Mint:
 forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
And try to install the RTAI kernel instead of the RT-Preempt one:
linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI
Time to create page: 2.810 seconds
