Won't boot
26 Nov 2020 18:36 #190345 by AdamD
Won't boot was created by AdamD
I got a new computer dell optiplex 9020. install with DVD failed it would get part way through install have issues then i couldn't even get into bios i had to pop the battery out to reset bios. Then I tried bootable usb got it installed. Now it won't boot. I am about to give up on linuxcnc. Should not be this hard to install.
26 Nov 2020 18:58 #190348 by Aciera
Replied by Aciera on topic Won't boot
I'm sorry you're having a bad day. But you can't really blame LinuxCNC for not being able to get into your computers bios. That is not something you can blame any OS for because the OS is not yet involved at that point.
Not being able to boot maybe an installer problem but even that may not be related to Linux but maybe a hardware issue. Dell Computers are usually well suited for Linux.
26 Nov 2020 19:04 #190351 by AdamD
Replied by AdamD on topic Won't boot
I think it is the half failed install on the hard drive causing the bios issues. I pulled the hard drive out and formated it. I wish there was a list of what I need turn on and off in bios.
  • Moderator
  • Moderator
26 Nov 2020 19:39 #190358 by tommylight
Replied by tommylight on topic Won't boot
Turn off:
power saving
speed step
hyperthreading
virtualisation
uefi
modem
TPM
26 Nov 2020 21:20 #190376 by AdamD
I have to unplug computer to get it to reboot with linux
27 Nov 2020 00:07 - 27 Nov 2020 00:30 #190383 by AdamD
I have installed seems to work now the hard work starts.
Thanks for the help.
Last edit: 27 Nov 2020 00:30 by AdamD.
Time to create page: 0.243 seconds
