Cannot install 2.8.0 on Ubuntu 12.04 from buildbot
- deusex25
18 Dec 2020 19:57 #192372
by deusex25
Cannot install 2.8.0 on Ubuntu 12.04 from buildbot was created by deusex25
Good day.
I'm trying to install LinuxCNC 2.8.0 as per guide on buildbot page.
Have added the key, and updated the repository list accordingly:
Precise (arch: i386) deb buildbot.linuxcnc.org/ precise 2.8-rt
realtime with RTAI deb-src buildbot.linuxcnc.org/ precise 2.8-rt
The system has the most recent updates, but if I try to install linuxcnc, I get the following error:
linuxcnc@LinuxCNC:~$ sudo apt-get -y install linuxcnc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc : Depends: linux-image-3.4-9-rtai-686-pae but it is not installable
Depends: rtai-modules-3.4-9-rtai-686-pae but it is not installable or
rtai-modules-3.4-9 but it is not installable
Recommends: linuxcnc-doc-en but it is not going to be installed or
linuxcnc-doc
Recommends: python-pyqt5 but it is not installable
Recommends: python-pyqt5.qsci but it is not installable
Recommends: python-pyqt5.qtopengl but it is not installable
Recommends: python-pyqt5.qtsvg but it is not installable
Recommends: python-pyqt5.qtwebkit but it is not installable
Recommends: python-opencv but it is not going to be installed
Recommends: python-rsvg but it is not going to be installed
Recommends: python-dbus.mainloop.pyqt5 but it is not installable
Recommends: gstreamer1.0-tools but it is not installable
Recommends: python-espeak but it is not going to be installed
Recommends: pyqt5-dev-tools but it is not installable
Recommends: hostmot2-firmware-all but it is not installable
E: Unable to correct problems, you have held broken packages.
I have tried 2.7.0 and 2.9.0 as well. The only difference in the amount of recommended packages. In all cases it cannot find linux kernel image.
Any idea, guys?
linuxcnc-doc
Any idea, guys?
- Thank you received: 7488
18 Dec 2020 20:04 #192375
Replied by tommylight on topic Cannot install 2.8.0 on Ubuntu 12.04 from buildbot
Did you enable the "unstable packages" and the "source code repositories" in the software sources from the administration menu?
Also did you run:
sudo apt-get update
before trying to install LinuxCNC ?
Also did you run:
sudo apt-get update
Time to create page: 0.144 seconds
