Boot Manager Question
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
22 Dec 2020 20:17 #192857 by Project_Hopeless
Boot Manager Question was created by Project_Hopeless
I bought a refurb PC with Win7. I loaded a Mint/LinuxCNC package and it setup a separate boot-able partition so I could boot in Win7 or Mint. I've been running LinuxCNC this way for almost a year.
I want to give the official Buster distro a try, I'm seeing better jitter results testing with the live CD.
My question... will loading Buster create a third boot-able partition, or overwrite the Mint partition or something else?
Ideally I like to keep all three. But if that takes too much work I'd settle for the next best option
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
22 Dec 2020 21:20 - 22 Dec 2020 21:22 #192862 by Todd Zuercher
Replied by Todd Zuercher on topic Boot Manager Question
You can keep your old installations and install the Buster iso to a new partition. But you will probably have to resize one of your existing partitions to make room for it (assuming you didn't leave empty unpartitioned space on your HD.) This isn't hard from the installation menus as you are installing.
Generally Windows partitions don't like to be resized, and you end up having to fix the Windows install after resizing it. (Something I'm sure you had to deal with when you installed Mint before.)
First check that you have enough free space in the partition you plan to resize. Then boot the install iso. When you get to the partitioning screen select manual. Then select the partition you want to resize. Put in the new size. Then select the newly created free space and partition it, and set as installable. You can share the swap partition you used with Mint. Then install.
It's been a while since I've done this, hopefully I didn't skip too many steps or get them wrong to keep you from figuring it out. You can also Google more specific instructions and watch a tutorial vid or two. Most any generic Debian install instructions should cover this.
Last edit: 22 Dec 2020 21:22 by Todd Zuercher.
23 Dec 2020 10:06 #192943 by Mike_Eitel
Replied by Mike_Eitel on topic Boot Manager Question
A simple ssd cost ca 20 - 30 bugs. Plus is much faster.
M5c
Mike
Time to create page: 0.119 seconds
