Linux stuck with blinking cursor
- FedX
28 Dec 2020 13:24 #193361
by FedX
Linux stuck with blinking cursor was created by FedX
I tried to install the buster linuxcnc 2.8 image on my main computer at home, to test a new interface.
But I ran into trouble, I think it could have something to do with the hardware:
CPU: Ryzen 3700x
GPU: AMD 5700xt
Ram: 32gB DDR4
After booting it enda up with a blinking cursor in the upper left corner..
I also tried to install the newest debian 10 image with online packages. But this also doesn't boot up it stucks in the section "Started GNOME Display Manager"
I think it has something to do with my graphics card.. but how can I get Linuxcnc and debian 10 to run?
Best regards
CPU: Ryzen 3700x
GPU: AMD 5700xt
Ram: 32gB DDR4
Best regards
- Thank you received: 7488
28 Dec 2020 13:47 - 28 Dec 2020 16:50 #193365
Replied by tommylight on topic Linux stuck with blinking cursor
Give this a try, it uses the non-free version of Debian 10 so it has drivers for a lot of hardware that the free version does not have, so might work.
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
I have a Ryzen 5 3500X with an RX480 on an Gigabyte Aorus Elite MB running Linux Mint 20 with Preempt-RT kernel and AMD proprietary drivers working properly ( just do not expect the same 3D graphic performance with the RT kernel as with the generic one, it is a lot lower )
The Mint howto is here, but beware that if you intend to do development work on the new GUI's like QTVCP or QtPyVCP you are better off using Mint 19.3 as the 20 uses Python3 for everything, making it nearly impossible to get the Python2 stuff to work.
forum.linuxcnc.org/9-installing-linuxcnc...-nearly-easy-install
Or if you want the Mint 19.3:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Last edit: 28 Dec 2020 16:50 by tommylight.
- FedX
28 Dec 2020 15:35 #193368
by FedX
Replied by FedX on topic Linux stuck with blinking cursor
Thank you this looks definitely more promising. I installed mint 19.3 as I want to use probe basic and customize it to my needs.
But I have problems with the graphics driver.. I can set the resolution only to 1024x768. On the AMD homepage there is no driver for Debian.
28 Dec 2020 16:49 #193370
drivers.amd.com/drivers/linux/amdgpu-pro...-ubuntu-18.04.tar.xz
Those work on Mint 19. Might be better off using the open source ones if you intend to use the RT kernel all the time, otherwise you can switch the kernel at boot time holding the shift key down till the grub menu appears.
- FedX
28 Dec 2020 17:53 - 28 Dec 2020 18:10 #193372
by FedX
Ok I installed the driver but it seems that this makes it worse...now the system does not boot any more and I get a fault..
Amdgpu: GCVM_L2_Protection_Fault_Status:0x00041F52
I can only boot in recovery mode
Last edit: 28 Dec 2020 18:10 by FedX.
28 Dec 2020 19:18 #193377
The following user(s) said Thank You: FedX
- FedX
28 Dec 2020 22:07 - 28 Dec 2020 22:15 #193381
by FedX
Im sorry i dont use Linux very often.. With Kernel 5.8 everything is working fine and im finally able to use probe basic gui
On my real machine i use older Hardware an dual core Opteron and 4gb DDR with an radeon X1950pro. Is it better to use Buster there or doesn't it matter and i can use mint also? For signal generation i use a Mesa card.
Last edit: 28 Dec 2020 22:15 by FedX.
28 Dec 2020 22:41 #193382
Use Mint 19.3 but with XFCE, it is easier on the hardware by quite a bit.
It is the same install procedure as for the Mate version.
- FedX
28 Dec 2020 23:11 #193385
by FedX
Ok I'll give it a try.
On my computer now with Mate and the 5.8 kernel i have a ridiculously high jitter of 12900ms base thread. How is that even possible with this powerful hardware?
28 Dec 2020 23:25 #193386
Has nothing to do with powerful hardware, it has to do with timings and C states of the processor and power saving stuff and interrupts and ......
And there is no need for base thread/period, only if using a parallel port.
Time to create page: 0.411 seconds
